Cat launches new electric forklift
- 20 Nov 2025 ( #1257 ) - Texas, United States
The new Cat ECQ Series cushion tyre forklift
Cat Lift Trucks has launched its new ECQ Series of electric forklifts with capacities between 4,000 lbs (1,814kg) to 8,000lbs (3,629kg).
The EC20Q-EC40Q series cushion tyre forklift has a lift height of 26 ft. (8m), can move at speeds of 12.3 m/ph and is powered by either a 36V or 48V lead-acid or lithium-ion battery.
Other features include an advanced drive system with no brushes or commutator, hydraulic and electric (optional) power steering and passive sway control which automatically senses load weights and mast movement when lifting above 12.5 ft. (3.8m).
Curve control means the forklift automatically senses light weight, steer angle and speed, adjusting the speed according to operating conditions.
Lift control allows for automatic sensing of load weight and mast height and automatically limits travel speed to 1.8m/ph when the forks are above 6ft (1.8m) and adjusts the lifting and lowering acceleration to reach top hydraulic speeds without bouncing the load.
It is suitable for freezer conditions, features electronic back-up smart alarm and foot direction control, and has an optional two drive-in racks for different applications.
“This isn't just an electric forklift,” Cat states. “It's a revolutionary machine built to handle more and cost businesses less.
“By engineering it with advanced 48V lithium-ion power, we’ve created a truck that delivers the high performance of an internal combustion (IC) truck with all the uptime, efficiency, and intelligence you expect from electric.”
Stacker Briefs
Stacker Briefs 14 Aug 2025 - 1 min read
EP launches forklift on Brazilian market
EP launches forklift on Brazilian market 24 Jul 2025 - Brazil - 1 min read
Konecranes launches e-hybrid RTG
Konecranes launches e-hybrid RTG 19 Jun 2025 - Rotterdam, Netherlands - 1 min read
Cat expands reach trucks range News Story - 26 Aug 2021 - Almere, Netherlands - 1 min read
Briefs News Story - 27 Aug 2020 - 2 min read
Towlift expands to Pittsburgh News Story - 15 Sep 2016 - Pittsburgh, PA, United States - 1 min read
Lift Tek Elecar
Lift Tek Elecar
