Question on Chinese fork lifts
Yes I know they are not as good. I have imported a LOT of Chinese power products and some are ok, and getting better. I decided to stop. My son-in-law is opening a new fabrication shop and is LIMITED on funds, He needs a forklift that can upload pallets and put pallets back on a truck. It does not need to be fast, it's not running docks. It will get used a few hours every few weeks. I am curious about these Chinese electrics. I just don't want a beater forklift with 90000 hours dripping all over my shop. Any experience with these?https://www.facebook.com/share/thXFYSSNwycgSLoY/
  • Posted 29 Oct 2024 08:39
  • By Paul_Holt
  • joined 29 Oct'24 - 7 messages
  • Oklahoma, United States
Showing items 1 - 20 of 21 results.
Chinese forklifts are garbage, buy you a Toyota if you want quality
  • Posted 28 Apr 2025 12:00
  • By Johnny_young
  • joined 7 Jun'24 - 3 messages
Johnny young
Chinese electric forklifts and lithium battery technology have made significant improvements in recent years. Many brands have not only enhanced quality and efficiency but also become more competitive in terms of cost. For your needs, if the forklift will be used infrequently, choosing a Chinese-made electric forklift is undoubtedly a more cost-effective option. Moreover, with continuous advancements in technology, the quality and after-sales support have been steadily improving.
While earlier some Chinese brands may have had issues with after-sales service, many manufacturers now have established global service networks to ensure that customers can receive timely technical support and spare parts. This way, even if the forklift is used occasionally, you can ensure its proper functioning and avoid unnecessary maintenance issues.
  • Posted 2 Apr 2025 15:14
  • By William_Jiang
  • joined 2 Apr'25 - 1 message
  • Anhui, China
@ Dexter1212
Guess you read about what happened at the Alamo
PS: Lived in Waco and Katy before that 26 lane I-10 freeway (aka Katy Freeway was being built. Moved to Georgia in '96 (just in time)
  • Posted 24 Nov 2024 04:24
  • Modified 24 Nov 2024 04:25 by poster
  • By johnr_j
"Have An Exceptional Day!"
I will stay out of this one!
  • Posted 24 Nov 2024 02:18
  • By Dexter1212
  • joined 30 Nov'21 - 65 messages
@lifter01
Learned this many decades ago like 6.5 decades.
There are some people that will lie a little, cheat a little by will be absolutely sincere about it
  • Posted 13 Nov 2024 05:48
  • Modified 20 Nov 2024 22:13 by poster
  • By johnr_j
Your full of yourself fella. You can but a machine and set it on fire if that floats your boat, but you cannot modify it in anyway without the manufacturers OK to carry out the modification. We have regulations in place (loler and puwer in the UK osha USA) to stop idiots like you killing themselves or others pal
  • Posted 13 Nov 2024 00:38
  • By lifter01
  • joined 4 Jul'09 - 463 messages
Not how to win friends.
Math is used on a tilt table to determine the tip over point of the forkli lift stability triaangle and position of the center of gravity at various tilt table angles while the mast is tilted back and adjusted to various positions with the mast like vertically with full rated load and mast adjusted to true vertical of the 4' x 4' x 4' test loads as masts will bend forward some mor than others; also forks raised 6" off the floor and mast tilted back ward. In case of a CB electric they are tested for minimum weight batteries and max weight batteries.
In a nutshell don't think any shade tree engineering will have the capabilities and equipment to do what you state Plus your forklift MUST have an appropriate capacity plate issued by the manufacture of your brand of lift / OSHA standards.
Have a good day Have an accident with the forklift you played with and you'll or your son see OSHA in a NY second will be able to do that much less pass any of the required.
  • Posted 12 Nov 2024 06:20
  • By johnr_j
You're from OK, that speaks volumes...
  • Posted 12 Nov 2024 05:19
  • By brent_b
  • joined 29 Apr'10 - 7 messages
  • Indiana, United States
These replies. I can do math. You idiot just want to hear yourself talk, if this is the level of blue collar workers in the country or the UK, everyone is screwed. I have a degree in MATH. I can do it, apparently no on on this site can. Aka. Forklift Action. I think I will seek advise from other places with people that have a IQ over 10. Best of luck folks. By the way, this had NOTHING to do with the question I asked. Learn to read and go outside, most of you need it.
  • Posted 12 Nov 2024 02:35
  • By Paul_Holt
You can't even spell, and you're trying to educate people. You know the guy you work for? I am that guy. We are different. Go take a physics class. And I can do anything I WANT too that forklift, ITS MINE. I can set it on fire if I want. LOL, what a joke.
  • Posted 12 Nov 2024 02:33
  • By Paul_Holt
Well apparently I dont want you working on the 100 I have owned. 5 AGM batteries that are under your NUTS, DO NOT add much ballast weight to the lifting of the machine, so yes if you put a lighter lithium pack in the lift, you could re-ballast the weight with rocks if you wanted. You obviously did not take physics and don't know basic math. I assure you I do. GAWD some of these replies are the dumbest things I have read in some time. Just FYI those batteries weigh a total of 350 lbs. And if you want me to draw you a diagram on leverage and show you how LITTLE effect 350lbs has on the LEVER of that machine when they are in the front 60% of the weight load I can take you back to school. Listen in math and learn, or just listen to some idiot on this site. I bought a hyster, so if I put an aluminum bottle on it instead of metal, do I lose all lifting capacity? Its MATH.
  • Posted 12 Nov 2024 02:31
  • By Paul_Holt
Paul I've been in the industry for over 40 years pal as both an engineer and loler inspector and can assure you I am 100% correct as john_r stated the battery minimum weight is part of the ballast and cannot be changed without the manufacturer say so.
Stuck to what you kniw about because you know nothing about forklifts
  • Posted 10 Nov 2024 05:53
  • By lifter01
The counterweight + a minimum weight battery or maximum weight battuer MUST be used for safety issues. The owner of the forklift MUST get the manufactures or authorized distributor written approval to add weight and where. Rated capacity of any counterbalance forklift is not just the teeter tauter principal, The capacity is based on the stability triangle and the CG is also measure at maximum lifting height and bast tilt angle.. Capacity is verified on a tilt table to measure sidae to side tip over points
Shad tree engineering can get you in to real trouble. - Philadelphia lawyers get rich on shad trees.
BTW I only sent from December 1967 thru October 2007 in the lift truck industry.
Hint : Read the OSHA standards and the latest ANS B56.1 standards (might be called SAE standards now) on the does & don't and responsibilities of the owner/driver of owning a lift truck. Hung up my lift truck spurs in 2007.
GL
Ciao & Pura Vida
PS: Won't provide you any more info as it seems you have answered you concerns all by your self.
PSS: Like I stated in my previous post - you provided sketchy info at best in your post. And all replies did not even cost you a "Yankee Dime"..
PSSS: A Yankee dime for those that aren't familiar withe that term is a kiss on the cheek. "Learnt" that from my "Lone Star Lady" of 42+ years. And that is all I will ever wager on a bet because even when you loose you win.. For the record I only bet Y.Ds. with the ladies
  • Posted 9 Nov 2024 06:56
  • Modified 10 Nov 2024 19:28 by poster
  • By johnr_j
LOL, you are 100% wrong. These electric forklifts (modern) do not use huge 72V batteries with 3-phase chargers made for fast-moving warehouses. Those types of lifts use the battery as a counterweight. The forklifts I was referring to have 5 30 series AGM batteries that MIGHT weigh 450lbs, the machine has a standard cast tail counterweight and the batteries are under the seat, the batteries contribute VERY little to the lifting ability of the machine. Some of these replies are not thought out very well. I can do math and adding weight for a lighter battery is not rocket science.
  • Posted 9 Nov 2024 03:00
  • Modified 9 Nov 2024 03:02 by poster
  • By Paul_Holt
There is a link in my post. I did not buy it. I bought a Hyster.
  • Posted 9 Nov 2024 02:57
  • By Paul_Holt
The Safe Speed Of Forklifts Is Usually Between 3 To 5 Miles Per Hour (5 To 8 Kilometers Per Hour).
The Safe Speed For A Forklift Is One That Allows The Operator To Maintain Control Of The Vehicle,React To Potential Hazards Promptly,And Navigate The Workspace Without Causing Harm.
Factors Influencing Safe Speed
Workspace Conditions:The Layout Of The Warehouse Or Industrial Setting,Including Aisle Widths,Traffic Patterns,And The Presence Of Obstacles Or Pedestrians,All Impact The Appropriate Speed For A Forklift.Narrow Aisles Or Busy Areas May Require Slower Speeds To Ensure Safety.
Load Stability:The Stability Of The Load Being Carried By The Forklift Is Crucial.Higher Or Unstable Loads May Necessitate Slower Speeds To Prevent Tipping Or Other Accidents.
Operator Experience And Training:The Skill And Experience Level Of The Forklift Operator Also Play A Role In Determining A Safe Speed.Properly Trained And Experienced Operators May Be Able To Navigate At Higher Speeds Safely,While Newer Or Less Experienced Operators May Need To Operate At Slower Speeds.
Regulatory Requirements:Safety Regulations And Standards, Such As Those Set By OSHA (Occupational Safety And Health Administration) In The United States, May Provide Specific Guidelines Or Limits On Forklift Speeds.
By Adhering To Safety Considerations And Choosing The Right Model For Your Needs,You Can Maximize Its Efficiency And Effectiveness While Ensuring The Safety Of Your Operators And Workspace.
The Telescopic Telehandler Forklift Is A Powerful And Versatile Piece Of Equipment That Can Be Used In A Wide Range Of Applications.
Here's An Overview Of This Type Of Forklift:
Key Features
Telescopic Boom:The Most Distinguishing Feature Of A Telescopic Telehandler Forklift Is Its Telescopic Boom,Which Allows The Operator To Extend And Retract The Lifting Arm To Reach Different Heights And Distances.This Feature Makes It Ideal For Tasks That Require Lifting And Moving Loads Over Obstacles Or Into Tight Spaces.
Attachment Versatility:Telescopic Telehandlers Can Be Equipped With Various Attachments,Such As Forks,Buckets,Pallet Handlers,And Aerial Platforms,To Perform A Wide Range Of Tasks.This Versatility Makes Them A Valuable Asset In Diverse Work Environments.
Powerful Hydraulic System:The Hydraulic System Of A Telescopic Telehandler Forklift Provides The Necessary Power To Lift And Move Heavy Loads.It Also Allows For Smooth And Precise Control Of The Boom And Attachments.
Four-Wheel Drive And Steering Options:Many Telescopic Telehandlers Are Equipped With Four-Wheel Drive And Various Steering Options, Such As Front-Wheel Drive With Rear-Axle Steering,To Enhance Maneuverability And Stability On Uneven Terrain.
Maximum Speed Limit:Many Workplaces Set A Maximum Speed Limit For Forklifts,Often Around 5 To 8 Miles Per Hour (Mph),Depending On The Specific Conditions And Regulations.
Here Are Key Aspects To Ensure Safe Operation:
1.Safety Cage:Many Telehandlers Come Equipped With Safety Cages To Protect The Operator And Any Passengers.
2.Proximity Sensors:These Sensors Detect Nearby Obstacles,Reducing The Risk Of Collisions.
3.Pedestrian Detection System:Alerts Operators To The Presence Of Pedestrians,Enhancing Site Safety.
4.Forklift Safety Devices:These Include Load Indicators,Which Prevent Overloading,And Stability Monitoring Systems To Prevent Tipping.
5.Safety Training:Operators Must Undergo Proper Training To Understand The Telehandler's Controls And Safety Features.
6.Regular Maintenance:Routine Checks And Maintenance Ensure The Machine Remains In Safe Working Condition.
As Technology Advances,New Safety Devices And Systems,Such As Pedestrian Detection And Collision Avoidance Systems,Are Becoming Available To Further Enhance The Safety Of Forklift Operations.Telescopic Telehandlers Are Invaluable For Their Lifting Capabilities And Versatility.
The Telescopic Telehandler Forklift Is An Indispensable Tool In Modern Industry,Offering Unparalleled Versatility And Efficiency.By Embracing Both The Capabilities Of These Machines And The Necessary Safety Measures,Operators Can Maximize Productivity While Minimizing Risks In Their Work Environment.
  • Posted 4 Nov 2024 19:43
  • By GuiYun_Liu
  • joined 14 Oct'24 - 1 message
  • China
Liu GuiYun
What type of electric fork it do you have - Stand Up Rider, Sit Down Rider, Walk or Walk Behind with tiller steer arm with vertical mast lifting?????. You seem to already have this unit as you say you can't ID the make. The Chinese are famous for branding the same forklift with different funny names. Linda like eating" canned mystery meat".
The Chinese might have taking lessons from" Sir"** Neville Bowman Shaw & side kick Trevo aka Lancer Boss and shipped the same model side loader with a different engine and/or transmission for the sam end user in Houston, Texas without any advanced warning of these temporary changes. True story. Allis Chalmers had a private label agreement with LB in the early 70s. I was the corporate Products Sales Manager when that happened WTF. Both AC and Lancer Boss died the death of an raged doll - one sooner than the other.
"" Yes Neville The Devil was knight eventual - his lifes dream.
  • Posted 4 Nov 2024 04:56
  • By johnr_j
You cannot just change batteries on an electric forklift to anything you want. The safe working load of the machine relies on the weight of the battery which is part of the ballast of the machine. Change the battery and the machine will need to be re rated unless the battery is exactly the same weight of the original battery
  • Posted 3 Nov 2024 23:02
  • By lifter01
I dont care about the batteries, they are AGM batteries, if they go out in a year I can put a Lithium Phosphate pack in it for a few grand. I am more concerned about the hydraulic pumps and drive. I can't figure out who made this lift.
  • Posted 2 Nov 2024 07:22
  • By Paul_Holt
If you decide to go down the Chinese route I don't kniw tge situation in the USA but in Europe the only ky one I would consider is EP we sell EP along with other more premium brands and we find support from the factory to be very good and parts back up good as well (far better than BYD) and the trucks are holding up quite well too (once again compared to BYD) yes still behind a usa built European or Japanese truck (not that far anymore) zapi controllers (so no unheard of Chinese knock off controller that you cannot replace) etc but probably the cheapest half decent lithium ion truck on the market
  • Posted 1 Nov 2024 09:04
  • Modified 1 Nov 2024 09:05 by poster
  • By lifter01
JCB 533-105
Toyota 02-8FD25
Oxford Ct, United States
Columbus, United States
GemOne
