Product News
- 1 May 2014 ( #665 )
The new reach truck range from Cat Lift Trucks.
New Cat reach truck range
Almere, The Netherlands
Cat Lift Trucks has introduced its NR-N2 reach truck range, which it says was designed for "increased profitability by maximising performance, empowering operators and cutting costs".
Key to the reach truck's productivity is the Responsive Drive System (RDS). The system's advanced mast handling features speed up lifting and lowering, smooth out the starts and stops during reach movements and give accurate control of tilting and side-shifting.
RDS also includes new mast and reach technology, for high stability and minimal sway, and a choice of user-set performance modes or engineer-customised settings for different needs.
The maximum lift of the poweRamic mast is 13 m (43 ft.).
Upgrade to largest model telehandler
Rocester, United Kingdom
JCB has upgraded its largest model, the 540-200, with the adoption of an EU Stage IIIB/US EPA Tier 4 interim driveline.
The 540-200 is JCB's first telehandler to be equipped with a five-section telescopic boom. It is powered by JCB's Ecomax diesel engine, delivering 109hp (81kW), up from the previous machine's 100hp (74.5kW). The machine is also available with the option of a 125hp (93kW) version of the JCB Ecomax engine.
The machine, with a 20 m (66 ft.) lift height, will make its UK show debut at Vertikal Days 2014 on 14-15 May at Haydock Park, which is halfway between the cities of Liverpool and Manchester.
TPS introduces new compact crane
Singapore
Terex Port Solutions (TPS) has launched its first mobile harbour crane, the Terex Quaymate M50, designed as an entry model for small maritime and river ports.
With a diesel-electric drive, the purpose-built crane model, with 50T maximum lifting capacity, 36 m (118 ft.) radius, and 50 m/min (160 ft./min) hoisting speed, provides operators of smaller ports with an economical as well as environmentally and user-friendly machine.
It is designed for light- to medium-duty application, cost-effective working speeds and a life cycle appropriate to the application. The crane is designed by an international team of engineers, using Asian and European-made components and is made at the TPS plant in Xiamen, China.
Briggs adds Maximal range
Toyota halts IC shipments in US
Toyota halts IC shipments in US 27 May 2021 - Columbus, IN, United States - 3 min read
Product news
Product news 31 Jan 2019 - 2 min read
Cat expands reach trucks range News Story - 26 Aug 2021 - Almere, Netherlands - 1 min read
Briefs News Story - 27 Aug 2020 - 2 min read
Towlift expands to Pittsburgh News Story - 15 Sep 2016 - Pittsburgh, PA, United States - 1 min read
Modern switches brands News Story - 8 Oct 2015 - Bristol, PA, United States - 2 min read
Product News News Story - 30 Apr 2015 - 2 min read
Product News News Story - 2 Apr 2015 - 3 min read
