What motor is in this? It's a C500 Y40 not a HY40
I'm looking at a Clark C500 Y40 with a bad motor and the owner don't know what it has. It's been sitting for a few years. The oil filter says 3674 hrs. written on it at last change. Price is right but are there parts available.
  • Posted 19 Mar 2025 08:44
  • By David_Schulz
  • joined 19 Mar'25 - 3 messages
  • Oregon, United States
David Schulz
Thanks for the reply. I finally had time to go look at it yesterday and am going to pass it had a lot wrong that the seller didn't mention. Thanks again
  • Posted 23 Mar 2025 04:53
  • By David_Schulz
David Schulz
They are still available although expensive
All state ag parts has rebuilding kits
Seals etc around 250 but that's just for the gaskets and seals have you ever rebuilt one ?
It is a wet sleeve engine that has a balancer bolted to the bottom of the engine by the main bearing cap it has a gear that drives it from timing gears I always took it off and tapped the holes and put short bolts in the holes it is there in case you want to make it a diesel
I have done several in the past when you knock out the sleeves they have o rings on them when you replace them use anti freeze as lube not grease !
  • Posted 22 Mar 2025 07:20
  • Modified 22 Mar 2025 07:25 by poster
  • By John_Bradley
  • joined 10 Aug'22 - 311 messages
Jb69
Thanks for the reply. Its not a Flathead. The valve cover says Clark Equipment. How hard would it be to get Waukesha parts?
  • Posted 21 Mar 2025 10:03
  • By David_Schulz
David Schulz
Probably a D-155 G Waukesha
If it has a flat head it is a continental 226
Clark used Waukesha in a lot of those older units
  • Posted 21 Mar 2025 03:55
  • Modified 21 Mar 2025 03:56 by poster
  • By John_Bradley
Jb69
The term 'Genuine Leather' is not used to reassure you that the product is made of leather, but rather to indicate that the lowest quality of leather is used.
edition #1303 - 15 October 2026
In this week’s Forkliftaction News , we report on a number of product launches including an Auto-Navigation Forklift Robot from Chinese equipment maker Leapting, developed for utility-scale solar construction sites... Continue reading
Linde Material Handling
