Allis Chalmers FPL40-24-2PS "Cotton"? Forklift
Recently I bought early '70s? vintage AC FPL40-24-2PS pneumatic tire forklift with Buda, 4B-153, OHV, 4 cyl. propane engine & Borg Warner T11 two speed auto. trans. (rigid machine!)
I bought a engine/trans. parts manual on ebay - In looking through the manual I noticed various part #'s as being for a "Cotton Unit". I was hoping one of you really checked out A/C guys might know what that was? I noticed the front engine crankshaft pulley was a 2 belt for the "Cotton Unit" as opposed to a 1 belt as mine is - but then some of these had an "Oil Clutch" paired with a manual trans. so ???
Thanks for any info.
  • Posted 9 Mar 2013 15:42
  • By jake38311
  • joined 9 Mar'13 - 5 messages
  • OH, -
Showing items 1 - 20 of 24 results.
The FTP60-24 is a basic 6000 lb.@24" load center rated lift truck with a 2 stage mast. If this model number is complete the unit is a gasoline engine powered (A-C G230 6 cylinder) with two speed "oil clutch" transmission that A-C built. The actual lift capacity rating would depend on the mast type (2 or 3 stage), mast lifting height & any front end attachments like a side shifter, fork positioner, etc. The serial number is stamped into the frame and on the truck data plate. This is an "older" model. My guess 1960's era and probably built at the Harvey, Illinois plant. But the s/n would be needed to determine that. There are serial number guides & maybe some "old timers' on these board might have more insight, than I - worked for AC from '67 t o' 81. Trashed all my lfit truck files 7 info two days after I retired in 2007.
Allis Chalmers went out of business in mid 80's - service parts & tech info are hard to find.
  • Posted 29 Sep 2016 19:55
  • By johnr_j
Hello
I have a forklift allis Chamlers model no FTP 60-24 but it's not written the capacity on it. Can you help or guide me how to know the capacity and model year. Thanks in advance
  • Posted 26 Sep 2016 22:55
  • By ahmed_m
  • joined 26 Sep'16 - 1 message
  • New Jersey, United States
Take it to a scrap yard they might give you that much for it - drain fluids first.
  • Posted 13 May 2016 08:13
  • By johnr_j
Anybody want this forklift for parts can have it for $500.
  • Posted 13 May 2016 06:11
  • By Antiqueron
  • joined 10 May'16 - 2 messages
Forklift help
If you do go the electric fuel pump route- make sure to T into the pressure line to the carb, install a variable restrictor in that line & run that line back to the tank.
I've found the either A)- the electric pump will over power the float in the carb over time (forklifts don't usually run high rpm's & the pressure backs up) or B)- the backed up pressure will destroy the pump over time.
Installing the by-pass back to the tank eliminates this issue
  • Posted 13 May 2016 00:55
  • By bbforks
you can try putting an electric fuel pump in, (you are running gasoline, correct?), as for plugs, those older engines could run on any plug of the same type. I think those plugs were short reach w/ a 13/16 head if memory serves me proper.
  • Posted 12 May 2016 07:56
  • By 7777
The engine would be an Allis-Chalmers G-153, 4 cylinder, OHV. Can't help w/the spark plug type. Allis Chalmers disappeared from the market place in mid 1980's so parts are a bit hard to find for a 35 year old unit. But if you contact Komatsu Forklift at (708) 385-0330 (Chicago area) and ask for Scott Eller (General Manger with service/parts background) he might be able to help you or email [email address removed]. Scott goes back to the days of Allis-Chalmers and has a bit of gray hair like me. Make certain you have the serial number - should be on the trucks name plate & stamped in the frame - can't recall where to find it. Spent my first 14 years in the lift truck business w/ A-C before having the opportunity in 1981 to seek new horizons. That is when I first met Scott - use my name if you want John Johnson. Hope this helps.
  • Posted 10 May 2016 21:08
  • By johnr_j
I have a f40-24. 1971 What is the engine and size of spark plugs? Where can I buy fuel pump etc? Thanks for help
  • Posted 10 May 2016 07:51
  • By Antiqueron
I grew up where you traveled South to get to
Canada & saw the famous Canadian, Gordie Howe, play at the Olympia when I was starting to shave once a month whether I needed to or not.. Enjoy Canada especially the Elora Gorge area in the fall & Labatt Blue.
  • Posted 24 Nov 2015 11:15
  • By johnr_j
thank you both for the quick reply's and ill check with both you're leads and let you know what turns up. see you in Canada johnr j and thanks 7777
  • Posted 24 Nov 2015 00:29
  • By dustin_m
  • joined 22 Nov'15 - 2 messages
  • Saskatchewan, Canada
I don' go back to the Buda days - Allis Chalmers bought them in 1952/54 for the engines and lift trucks were built in small quantities in a "back building" adn wer initially part of teh A-C engine division. I joined them in late 1967 At that time everything was badged Allis-Chalmer a the Buda engine was labled G153.
I can direct you to two people that "might" help you as they were long time AC dealers or had roots that went back to the "olden" days. Langer Material Handling, Valencia, Pa Kevin Langer a contact but his dad Bill would probably be the best person (he is retired but still looks over the kids shoulder). The other is Komatsu Lift Truck in Illinois, Bedford Park (Chicago area) I think - contact Scott Eller - he started in the Parts Department with the Allis-Chalmers factory store. You can find their contact info via Google search. The Buda history & A-C history has died the death of a ragged doll.
You can use my name to open the door a little -these contact a the "newer" kids on the block - I'm a young almost 71 - it will be official on that Boxing Day holiday in Canada.
  • Posted 22 Nov 2015 23:17
  • By johnr_j
very limited information on this truck but if you have a delco starter the # may be 4761273
  • Posted 22 Nov 2015 22:11
  • By 7777
Hey their , this is a message to john jr, it seems you know about these a c forklifts, and I have a question and I was hoping you could help me. I recently bought a ft 24 40 , sn 11303076, buda and the starter isn't any good. the part number is worn off and I cant seem to find a replacement. would you happen to know that part number is. the engine is a 4b153 and the sn on the engine is 374005. I have no idea what year it is or anything please help!!! thanks
  • Posted 22 Nov 2015 14:36
  • By dustin_m
HA HA
  • Posted 17 Mar 2013 00:53
  • By 7777
Well some days you are a diamond some days just a chunk of coal - I got lucky - thanks for you comment. But I did spent my 1st 14 years out of college with the lift truck division of A-C & I only have a touch of Alzeimers "Light" right now - my wife might want to argue that point but she isn't around right now to see me type this. See she will give a list of 10 things to buy at the store & garuanteed I will bring back 9 - I speed shop - in and out and repeat if necessary ( I woulg expand the rest of that thought but the FAC Admin might censor me).
  • Posted 16 Mar 2013 23:57
  • Modified 17 Mar 2013 00:10 by poster
  • By johnr_j
"Have An Exceptional Day!"
According to my book, Allis-Charmers used the following serial # system from 1955-1970, an 8 digit #
1960- s/n 16,947,000
1961- s/n 18,787,000
1971 the system changed to a all digit#
1st digit 1= plant #
2nd and 3rd 71 digit= year 1971
4th/5th digit month 01 =january
6th/7th digit production # 279
WOW johnj, talk about "knowing what your talking about," thats an incredable discourse, hats off to you.
  • Posted 16 Mar 2013 22:09
  • By 7777
Your truck was made in 1971.
  • Posted 15 Mar 2013 21:31
  • By duodeluxe
  • United States
duodeluxe
1. Sorry I don't have info as to year of manufactuer. When I retired I tossed all my forklift lift stuff in the trash including my serial number guide. But my 'guesstiamte" it is early 1970ish at best good possibility it is older as the engine was renamed to the G-153 and any referenced to the Buda company was gone when I joined the company in 1967. After A-C moved to a the Matteson Lift truck plant in 1970 they started using a s/n system with alpha & numerical numbers to indicate what plant the product was built in. The s/n you provided does not reflect that change.
2. Reasons for discontinuing the use of the A-C engine was for a couple of reasons - the main one was increase in cost (about doubled). Production volume in engine manufactuering is everthing to keep cost down. The A-C Engine Divison supplied a lot of generator sets that used the same engines as the lift trucks to the US government in support of the Vietnam Conflict. When the US withdrew from Vietnam, production volume fell off, cost went up. The lift truck division was they only significant user of this engine. The other reason corporate, David C. Scott, President, was looking for extra cash flow to support a five year mega buck "coal gasification" project that never panned out and cost reduction was the name of the game for all A-C operations as directed by corporate - they picked the F163/225 because it was cheap (marketing had no input but later did get blamed for loss of market share). At that time - only Clark & Yale had overhead valve engines & Cat was coming out with one in their lift trucks so the engineers & production folks said the "majority" of lift trucks supplies are using the Contiental wafle head engines. Talk about cutting off your nose to spite your face. David C. Scott screwed up Colt Industries before he came to A-C.
  • Posted 15 Mar 2013 21:17
  • Modified 15 Mar 2013 21:23 by poster
  • By johnr_j
Hi again-
I'm kinda directing questions to johnr j but I'd welcome anyone's input.
#1 My A/C FPL40-24-2PS (from above) is Serial# 17101279 - any idea what year it was made?
#2 Why did A/C quit using the overhead valve & sleeved 4B-153 engine and go to a gutless, flathead, slug continental engine?
Thanks Again
  • Posted 15 Mar 2013 14:57
  • By jake38311
  • OH, -
In the time period this unit was built, A-C market share in the commerical market for engine powered equipment was in the 10-12% in addition, A-C secured 1/3 of all US government & Ford Motor Company purchases which were signifcant at that time. Their demise was when they changed from the AC built engines to the Continetal flat heads F163/227 & imposed a 6.5% surcharge on all back orders as directed by corporate headquarters, even on direct sales (National Accounts) customers during a time peiod when lead time on new productions was 52 weeks plus & the US was faced with double digit inflation thanks to the smooth talking peanut farmer from Plains, Georgia. The surcharge was a major reason for the drop in market share - e.g. A-C was the number 1 supplier to GoodyearTire & Rubber prior to the surcharge then dropped to last place in a matter of a couple months. By 1982 market share dropped to about 4.5% which was still larger than Bakers in engine powered equipment.
I was there from '67 - '82.
There was a company that provided service parts i nthe Kansas City area taht warehosued parts in an old mine. They distriputed parts to former A-C dealers after A-C clsoed their doors adn sold the assest to ACMH in Columbus, Ohio, them later became Kalmar A-C who was bought by Komatsu. At that time their were a few people that new the older A-C parts & sourcing. When Komatsu moved from Georgia to South Carolina those people were not transfered and Komatsu had no interest in pursuing the segment of their business. Kinda' like "dying the death of a rag doll" - one cotton ball at a time.
  • Posted 13 Mar 2013 22:40
  • Modified 13 Mar 2013 22:50 by poster
  • By johnr_j
SMV (Konecranes) 4632CC5
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
