toyota 8fgu15 surges during idle
i have a toyota forklift 8fgu15 after a cold start it idles fine for about a minute then starts to surge and will die... if we have in gear and moving the mast slowly it seems to settle the idle... after the motor stalls and we restart it the motor instantly starts the surge... the surge is a loss in power not increase....
  • Posted 18 Oct 2025 23:31
  • By Frank_deLeon
  • joined 17 Oct'25 - 2 messages
thanks Frank deLeon
I am thinking this truck is running lpg if thats the case on the top of the lpg assian converter you will see a chrome plug sticking up the top is sealed break the top plug out in side is a screw turn the screw about 1 turn to see if it fixes it that is the air fuel mixture. Try in then out until the surge is not there. If that does not help you could need to clean the butterfly plate under the air horn take it out but be careful try not to get any cleaner near the moter of the govern or tps switches. Good luck
  • Posted 19 Oct 2025 00:13
  • By Scott_
  • joined 16 May'21 - 342 messages
Scott
  • By Scott_
Scott
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
Fishermen in the town of Oostduinkerke on the western tip of Belgium's coast practice a 500-year-old form of shrimp fishing. Known as paardenvisser, the fishermen trawl the shallow waters on Brabant draft horses, pulling funnel-shaped nets to capture the crustaceans.
