Shows 0% Charge batteries yet unit functions
Hey Boyz.....
My boss has asked me to look at several electric forklifts. Not my fortee.
This battery pusher has 24.7 volts after a full overnight charge....yet it shows 0% charge ??
Just wondering WTF....
Any help would be appreciated!
  • Posted 22 Aug 2014 23:21
  • By MickMike
  • joined 26 Feb'14 - 6 messages
I had the same issue. Having a 0 on the gauge prevents the forks from lifting but driving is ok. No codes. The battery is fully charged. for some reason, the circuit board stops reading the battery voltage. I replaced the circuit board in the arm and this fixed the problem. The part number is: TO 00590-47051-71
  • Posted 15 Jan 2015 00:27
  • By Rabbitt
  • joined 14 Jan'15 - 14 messages
Never too old to learn
If this is a 24v truck which i'm assuming it is.....
24.7v after an all night charge is not a good sign.
After charging a 24v system should be reading around 26 to 28v.
Do a load test on each battery if it has a battery pack with multiple batteries or if it has a single industrial battery use the hydraulics and load the system to see what kind of a load drop you have.
If testing single battery it shouldn't drop more than 1 to 1.5v, if the industrial type and it drops more than 4 or 5 volts under a full load in a 15 to 20 second loaded stall then you need new batteries.
Also plug the charger in and use a VOM and verify it is charging.
  • Posted 23 Aug 2014 02:16
The unit has a % charges display on the digital handle display. I am not sure if it is resetting it was operating normally about 6months ago
  • Posted 23 Aug 2014 00:25
  • By MickMike
Does the unit have a battery monitor.is it resetting. is it plugged in?
  • Posted 23 Aug 2014 00:22
  • By ray_j
  • joined 22 Aug'14 - 13 messages
  • Missouri, United States
Terberg RT403
Maxlion FD30
