Fault Code C013 - BT RRB2C
Hello everyone
Here is our story: We have a BT Electric Forklift has a problem with the movement of the forks. When they move upward they do not have problem but when they move downward, they move very slowly. On the same time, there is a message on the display screen of the forklift that shows Fault Code C013.
The problem is that we cannot recognize what is fault of this problem and we did not manage to find an explanation or more details about this Fault Code C013.
Could anyone advise us about this matter?
The details of this forklift are the following:
TYPE OF FORKLIFT: ELECTRIC (48V)
BRAND: BT
MODEL: RRB2C
CHASSIS/SERIAL NUMBER: 949010
YEAR: 2006
If you need any further details about this please let me know.
Thank you
Regards,
Andreas
  • Posted 16 Jul 2014 21:45
  • By andreas_s
  • joined 16 Jul'14 - 5 messages
  • ALAMBRA, Cyprus
Hello Gopal, I have sent you an email. did you get it? I have sent it from sadruddin.com
If not than can you share your email with me, mine is skhan855 at gmail dot com
  • Posted 24 May 2015 22:54
  • Modified 24 May 2015 22:55 by poster
  • By saleem_k
  • joined 18 Mar'15 - 19 messages
  • Punjab, Pakistan
Thank you for all the information you supplied.
We have replaced the magnetic sensor and the bearing sensor because both had problem. We also turned the potentionmeter screw for adjustment, it got better but now it needs programming for adjustment of the height of the mast.
We are now in the search of the programming tool interface that is used for these purposes.
Thank you for your help anyway!
  • Posted 12 Sep 2014 22:53
  • By andreas_s
  • ALAMBRA, Cyprus
Could also be the lowering pot screw on the A5 card has moved.
If the sensors & height counter are working correctly then remove the arm rest panel, on the large silver card with all the green & red led's roughly in the middle is a screw potentiometer - this can be used to trim the lowering speed.
Turning it anti clockwise will increase the lowering speed, just turn it a little bit at a time until the lowering speed is correct.
Once I've set these up I normally stick a little dab of silicone sealant on the screw to stop it moving from vibrations due to rough floors.
  • Posted 19 Jul 2014 02:09
  • By Forkingabout
  • england, United Kingdom
Hello Gopal
Thank you for your quick response!
We will check it out and let you know about it.
  • Posted 19 Jul 2014 00:16
  • By andreas_s
  • ALAMBRA, Cyprus
Hi, Check the 2 no's magnetic sensor of mast near to bearing sensor of mast, malfunctioning of these sensor will generate this problem,
If you have stock, Replace or try with removing any one sensor connection.
The truck will work without any problem.
Good luck.
  • Posted 18 Jul 2014 18:32
  • By gopal_s
  • joined 29 Oct'12 - 156 messages
  • karnataka, India
GOP
Sue Tomic Sue Tomic
Sue Tomic Sue Tomic
