Cat V50D head installation questions
One of our IC techs is working on a Cat V50D S/N 3E003799 with the Peugeot engine and the cylinder sleeves seem to be sticking up above the block deck just slightly., and they can be moved by hand a bit side to side. Is this normal and will the compress and seat when the head is torque down? What is the torque pattern and spec. ? Is there a special procedure for installing the head. I am pretty much clueless with IC trucks( I am an electric tech ) and the tech working on it speaks only limited English and my Spanish is as about as limited. Any advice would be of great help. Thanks
  • Posted 4 May 2013 02:18
  • By RAFARMER
  • joined 17 Jan'12 - 153 messages
rafarmerjr@gmail.com
Long winded or not, allot of good info, thanks LTRM
  • Posted 9 May 2013 18:18
  • By 7777
Having done at least a dozen of theses cylinder heads if the piston liners are allowed to move even the slightest while the head is off then little bits of cooling system scale will fall down between the liner and the block causing the surface to not have a good seal. Coolant will end up in the oil. Whenever we pulled those heads we would bolt on a special home made clamping device to hold the liners down and not allow them to rise up even the smallest amount. If those liners have moved you will need to pull the oil pan and remove the pistons and liners, the liner seals have tabs on them. Make sure you replace the liner seals with the correct number of tabs. I think there are three or four different thicknesses with different part numbers. You will not need to measure the liner height as long as you put the correct liner back into the correct hole with the correct liner seal. Sorry for the long winded response.
  • Posted 9 May 2013 15:35
  • By LTRM
  • joined 26 Jan'12 - 161 messages
  • Illinois, United States
Perkins AA diesels very similar. Pollution constraints had to be w/in certian limits. So an engine was developed w/ an absolute piston height max (.020 I think) above block. The head gasket made up the difference, while the angle torque settings on the bolts were designed not to allow over squeezing of the gasket. Then a manual rotation was done to insure the pistons were not smacking the head. Perhaps its the same idea.
  • Posted 5 May 2013 23:37
  • By 7777
As I remember, doing those 20 years ago, the cylinder sleeve is supposed to stick up a couple of thousands above the block. The sleeve just sits in there and is sealed on the bottom by a metal gasket against a flange on the sleeve. The gaskets come in different thickness to adjust how high the sleeve sticks up. The top of the sleeve is sealed when the head is bolted on. If they are sticking up a couple of thousands and the head is flat, I think you are good to go. 60 foot pounds torque starting from the center bolts and working outward, in increments.
  • Posted 4 May 2013 05:48
