Clark GPM20
Hi All
Can anyone help me with a service manual for this truck its a Clark GPM20 serial number M2650784 GEF7462
and can you tell me if the timing belt snapped, what if any damage to the valves would it do ?
ie bent
Thank you in advance
  • Posted 15 Nov 2012 03:49
  • By powerlifter
  • joined 17 Mar'09 - 306 messages
  • united kingdom, United Kingdom
A good engineer is a helpful engineer
I found this useful service info on Mitsubishi motors
http://www(dot)austarion(dot)com/tech/4g63.pdf
  • Posted 16 Mar 2013 22:19
johngen is correct. Clark uses(d) the 4G64 engine that was made in Korea under a license agreement. This engine required a crankshaft balancing system (lancaster type) to minimize vibrating when matched up to the Clark trans axle. The engines 4G63 & 4G64 used in Mitsubishi/Cat lifts were made at Mitsubishi Motors in Japan and matched to a trans axle made by Mitsubishi Heavy Industries (these engines did have a low speed (near idle speed) vibration issue for a period of time (in the mid 90's). It was still there in April,1996 (my last day to work for MCFA) as far as I can recall.
  • Posted 9 Dec 2012 08:51
  • By johnr_j
  • joined 3 Jun'06 - 1,452 messages
Its not correct
Gpm have no 2 belts of that serial number
The new one for the cgp have the old one have chain
Ore they put the new type in the Gpm
And the new one with balance look out you must have on the side 9Right side tha out screw put in 6mm stick to lock balance and then the mark of oil pomp set.
Other wise the motor wil shake
John.
  • Posted 8 Dec 2012 04:51
  • By johngen
  • NB, Netherlands
Thanks Lads for your help after checking i found Edward to be correct there was no damage to the valves and the job was very easy to do. The hardest part was finding the timing marks working within a confind place..
Once again Cheers lads
  • Posted 8 Dec 2012 01:39
  • By powerlifter
Hi Powerlifter,
Ed is correct there are 2 belts one which is the timing/cam belt (Clark p/.no- 920294) and the other is for the balance shafts (Clark p/no- 918712) dead easy to do, done loads of them and never had one do valve damage.
  • Posted 7 Dec 2012 23:28
  • By danny_k
this is a mitsu 4gxx motor in this truck, correct? usually if the timing belt breaks in the mitsu motor, you will just need to replace the belts, it is rare that it does other damage, but the valves are a possibility, and I think this one has 2 belts. (usually the belt does not break so much as looses a few teeth and slips out of time)
  • Posted 7 Dec 2012 21:08
But ithink there is mounted A chain not a Belt
John
  • Posted 7 Dec 2012 17:25
  • By johngen
  • NB, Netherlands
Its possible the valve damage
I send info But its possible its standing on disk
John.
  • Posted 7 Dec 2012 17:22
  • By johngen
  • NB, Netherlands
On the 88th day of the year, 29 March in a non-leap year and March 28th in a leap year, World Piano Day (also known as Piano Day) is celebrated. This date was chosen because a standard piano features 88 keys.
edition #1240 - 24 July 2025
CeMAT Australia 2025 has been underway in Sydney this week, wrapping up today, with the main topics coming out of the event proving to be the very predictable automation and sustainability... Continue reading
Yale Lift Truck Technologies
Simon Manasseh Simon Manasseh
VP business development for Europe, Noblelift Intelligent Equipment Co
Regional business manager, Doosan Bobcat Material Handling
President and CEO Swisslog Americas, Swisslog
Vice president, Newgentech Material Handling India
