Hyster R1.6H Fault Codes
Hi Guys,
I have a fault code that can not be found in the manual.
It is Mod 05 VMN High
Any advice on what this code relates to would be great.
Regards,
Alan
  • Posted 23 May 2012 08:15
  • By Heiby
  • joined 7 Sep'11 - 1 message
  • Victoria, Australia
helpfully
  • Posted 18 Sep 2019 17:48
  • By Ibrahimk
  • joined 6 Sep'19 - 7 messages
  • Saudi Arabia
Ibrahim A
I have a hyster reach truck R2.0. It come up with the fault Alarm Mod 05, VMN Low. im having the same problem.
I have had the forlift checked by Briggs who i must say have already charge me a chunk of money and still not fixed my fork lift.
The truck when you switch it on wont reset the drive wheel and therefore will not work and just throw up this code.
My current battery shows 49.9 volts, however i did attach a slave battery to my truck and that showed 51 volts.
When i then started my truck with the slave battery it then showed the same fault code but this time it said VMN High
Can anyone please advise me on how to fix my forklift
  • Posted 31 May 2015 22:07
  • By shakil_p
  • joined 31 May'15 - 4 messages
  • lancs, United Kingdom
Hi Lifter & all,
I need help on the above same truck. the truck will stop once turn the steering. error code is "steer sensor KO & capacitor charge". We found out the potentiometer near steer motor is loose.
zhou
at
skset
dot
com
  • Posted 10 Oct 2012 15:56
  • By joel_zhou
  • joined 5 Mar'09 - 31 messages
  • singapore, Singapore
Hi Lifter,
Do you have a workbook about the hyster r1.6 reachtruck.
i'm looking for it.
regards co
  • Posted 9 Sep 2012 19:55
  • By co_t
  • joined 10 Oct'10 - 29 messages
  • aan den lJssel, Netherlands
Hi
Mod 5 is the AC2 pump controller
VMH high(48V) possible causes
A, there is a problem in the motor cables or the motor power curciuts check the 3 phases are correctly connected also check for earth faults
B, faulty invertor
to check the invertor the pump and drive invertors are exactly the same the only difference is one of them has a link cable on one of the plugs they only take about 20mins to swap around aslo check the wiring to the multipin plug on the invertor i have had quite a few problems with broken wires where they go into the pins
another thing to check that might sound daft but on all the hyster matrix range it is critical that the beacon is ok a faulty or incorrect beacon will throw up all sorts of errors on these trucks i always disconnect it first and a lot of times the error disapears
  • Posted 24 May 2012 07:04
  • By lifter01
  • joined 4 Jul'09 - 462 messages
usually there is a numeric code preceding the Mod 05 VMN high reference.
The Mod 05 refers to the module faulting out if I'm not mistaken.
  • Posted 23 May 2012 21:24
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
Brussels Airport in Belgium, Europe is the world's largest sales point for chocolate, with over 800 tonnes of chocolate sold annually. This averages out to about 1.5 kilograms sold every minute.
