STILL R70-25T
HI ALL I HAVE A STILL R70-25T YEAR 1997 S/NO 70390543 RUNNING ON LPG. MY PROBLEM IS THAT IT WONT,START WHEN IGNITION IS TURNED ON THE LITTLE KEY LIGHT ON PANEL FLASHES WHEN TURNED TO START POSITION NOTHING HAPPENS CONTACTORS DONT EVEN PULL IN.
CHECKED ALL FUSES AND CONNECTIONS.
ANY IDEAS.
  • Posted 3 Apr 2009 18:51
  • By simon_a
  • joined 28 Jul'06 - 17 messages
  • south yorkshire, United Kingdom
Hi have you found the issues with your forklift ? As I have the same problem
  • Posted 11 Jun 2025 06:40
  • By MDF1
  • joined 10 Jun'25 - 1 message
  • United Kingdom
Mdf
hello my trolley still R70-30 has the same problem it starts but does not want to move can you help me thank you
[email address removed]
  • Posted 17 Jan 2022 08:48
  • By Karchexport
  • joined 17 Jan'22 - 14 messages
  • France
Vvv
Hi Simon,
R70 type 7039 has no starter motor, the generator is used to start engine. The direction lever must be the centre position, the neutral light must come on before you attempt to start the engine.
The batteries must be in good order, check them both.
Just for a quick test, remove the round monitoring plugs from drive motor and generator and try to start the engine. BUT do attempt to drive machine - make sure the handbrake is applied!!
Good luck
J
  • Posted 10 Apr 2009 22:02
  • By JBrad
  • joined 3 Feb'09 - 14 messages
  • Lancs, United Kingdom
Hi simon how you getting on with your still starting problem?
  • Posted 9 Apr 2009 06:15
  • By powerlifter
  • joined 17 Mar'09 - 306 messages
  • united kingdom, United Kingdom
A good engineer is a helpful engineer
its on the main fuse card, relay 9K2 controls engine starter solenoid located on the main fuse holder board behind the left hand front panel if its the one im thinking about.
  • Posted 5 Apr 2009 01:42
  • By powerlifter
HAVE CHECKED DIRECTION LEVER WHERE ABOUTS IS STARTER RELAY LOCATED.
  • Posted 4 Apr 2009 20:42
  • By simon_a
Have you checked starter relay and direction lever
  • Posted 4 Apr 2009 03:17
  • By powerlifter
Jim Tompkins Jim Tompkins
Sales operations, Heli
Taylor THC500L
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
