NEED HELP WITH FAULT CODES?
We're working on a Toyota 7bru18 that keeps shutting down while in motion. i keep getting the following fault codes ( 61,69,51, & 57). any help is appreciated. you can contact me directly at chivasn7 at sbcglobal dot net.
thanks,
jesse
  • Posted 30 Sep 2008 09:21
  • By glenn_levit7
  • joined 10 Jul'07 - 78 messages
Montacargas, Tequila y Limon!
Working on a 7BRU23, I changed the print board display but now I lost the reach/retract function. Configuration C8 is No Straddle, Tuning C5 is two speed, Both solenoids are OK, Voltage are ok 22v, but Lift Amplifier turns pump only between 9-12% RPM. All other aux hyd functions are OK turning pump at 30% RPM. Scanning pulses I can see the signal arriving ok to LPA. Does anybody some idea about this trouble? Thank you
  • Posted 13 Feb 2010 04:19
  • By luis_y
  • joined 24 Oct'04 - 29 messages
  • Lima, Peru
All makes, the best service.
Thanks
  • Posted 15 Nov 2008 07:37
  • By rich_k
  • joined 30 Oct'07 - 108 messages
Rich,
61 is steer error, 69 is steer limit feedback signal error, 51 is traction proximity sensor error, and 57 is traction pot voltage out-of neautral during POST. Hopefully this helps.
  • Posted 11 Nov 2008 09:58
  • By rogeriwt
I could only find 51(vehicle speed sensor open circuit) and 61(load sensor circuit open) I have had a similar problem before and it ended up being the battery Rich
  • Posted 11 Oct 2008 07:01
  • By rich_k
Terberg YT223
Aichi SR18A
VETTER Industrie GmbH
HD Hyundai XiteSolutions receives order for 230 forklifts Caracas, Venezuela, Bolivarian Republic Of
Columbus, United States
Oxford Ct, United States
