Code 522660-0
I have a Yale GLP070VXNDAE08 that shows a code of 522660-0 and then stops running like it ran out of fuel, I found that the throttle body was going bad so I replaced it and it seems to run better but still once in awhile it will show the code 522660-0 and then stops running. it had a broken fitting on the LP regulator for the fuel going to the carb, could not get just the fitting so I had to but the hole **** regulator. It was showing this code before I found the broken fitting after changing the reg it did not run any better until I changed the throttle body. The throttle body was making a lot of clicking noise like it was shutting on and off real fast the new one does not do that but still have the code that comes up and then dies. Any help would be greatly appreciated>
  • Posted 6 Nov 2018 08:58
  • By Gotcha2000
  • joined 15 Dec'17 - 42 messages
  • Indiana, United States
DTC 522660-0 - Adaptive Learning (LPG) Long Term Fuel Trim Low.
A. FUEL SYSTEM FAULT
B. EXHAUST SYSTEM FAULT
C. AIR INDUCTION SYSTEM FAULT
D. MIXER / REGULATOR FAULT
  • Posted 8 Nov 2018 00:20
  • By BREWSKI
Michel Denis Michel Denis
SMV (Konecranes) 4632CC5
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
USD1
