ECG30
can anybody help with this model of clark electric
ECG30 #ECG30-358-0035-6752FB????????
Thanks olly
  • Posted 12 May 2008 16:13
  • By Olly
  • joined 5 Feb'08 - 12 messages
  • New South Wales, Australia
G,day carl v
Thanks for the info, yes the truck is working as you have said.
I don't work on Clark electrics much , they are not a popular machine
here in Sydney. Once again thanks for the help
olly
  • Posted 2 Jun 2008 20:51
  • By Olly
-01 is a status code, usually for seat switch, hand brake switch, dead man pedal switch (stand-up), etc. Sounds like the truck is ok if it drives and the status code goes away. When code disappears then the display should show a 3 digit number, this is battery %.
  • Posted 30 May 2008 23:43
  • By carl_v
  • joined 12 Oct'07 - 76 messages
G,day carl v
thanks for information on the codes. With the codes -01 does this mean that
it is working correctly ?? When the brake pedal is not push down this code is on and stay on untill you jump on to drive away.?
thanks for the help
olly
  • Posted 29 May 2008 14:58
  • By Olly
-99 means that the service reminder interval has been tripped. With a GE Handset, set Functions 19 and 20 both to a value of 255 if you want to eliminate the service reminder. Then -99 will not appear again. On the reach truck, -01 will appear when brake "deadman" pedal is up.
-01 on the ECG, Park Brake switch open. Or Seat Switch open (if equipped), Slide in Battery retainer interlock switch open (if equipped).
  • Posted 24 May 2008 02:59
  • By carl_v
G,day Truck tech
Do you know where I can get information on fault codes???
I do not work on clark much. But lately my company has been
getting work to do with clarks.I have work on a clark reach truck
it comes up with 99 at start up then it has 01 when youare ready to start,I also have same 01 code on ECG30
any help is greatly appreciated
Peter
  • Posted 22 May 2008 17:25
  • By Olly
Yes. What exactly do you need?
  • Posted 13 May 2008 18:07
  • By Truck_Tech
  • United States
Airman ENCL045
Elwell-Parker ESI500-36
edition #1257 - 20 November 2025
