Good day. The screen shows 23 operating hours. Did you change the control unit? Perhaps the control unit has a different firmware installed.
??????? ???. ?? ?????? ?????????? 23 ????????. ?? ?????? ???? ??????????? ???????? ?? ????? ?????????? ????????? ?????? ????????.
Yours looks like it's set to snail mode.
Probably try increase speed settings or calibrate the footpedal
Hi, I'm having the same issue with my Jungheinrich forklift. It only runs at slow speed, while all other functions are working normally. The snail button is working, there is no red warning light, and no error message is displayed.
Were you able to solve this problem? If so, could you please share what the cause was and how you fixed it?
Thank you in advance.
Hi. Did you trace the thermal circuit wires back to the interface card? For TEST purposes only you can link out the points on the interface card.
Jack up truck and test if both wheels are turning at the same speed. If they are its unlikely both encoders are faulty so that would eliminate that as a possibility.
Also begin with recalibration of foot pedal.
You now you have 2 motors?
Its not good that red indication is always on.
I,m out off furder ideas, sorry.
Hi Mr. John,
Checked the traction motor Thermistor value is showing 49 to 51 ohms. Now Error 40 is not showing, But Motor over temperature red indication always on. still its running slow speed.
Traced the thermistor connection wiring, found all are normal.
40= overtemperature traction motor,
check wires and temp.sensor
Hi Mr. John,
Checked the sensor bearings, i didn't find any problem on the bearings, even then changed with new bearings. But the problem not yet solved. Machine running on slow speed only.
some time Error 0040 is coming on the dash.
I checked the dashboard, i think you can change the settings on the right side of the dash.
If it drives really slow, more like 1 meter a minut then the sensorbearings good be broken.
Hi John, thanks for your reply.
Machine serial no. FN324896
This problem happened suddenly while running,
waiting for your further advise.
Maybe somebody changed the driver settings on the dash,(driver 1/driver2/......)
Need serialnumber to see what type of dashboard you have.
