Ramzi
Punch in 5 5s again. At the display press the right arrow key until you see a little man int the screen. Press the enter button, then scroll up or down until you see what is in the picture you posted. Press the enter button again to enter the calibration menu. One note, raise the carriage off the floor
Before you start the calibration. I do not know if the service password will be all 5s. I am retired, but will try and do a little research. Good Luck
Hello Garland,
Thank you for your input. There is no dealer in our country at the moment. We know the supervisor password as it comes from factory is 55555. Do you happen to know what is the standard password for Service as it comes from the Hyster factory as no one has changed the passwords on the truck.
Thanks
Ramzi
Ramzi,
Suspect the hydraulic levers need to be calibrated. Will need service password to access calibration menu. May need to call Hyster dealer. Good luck
