Report this forum post
hi you can use a relay at the starter so what you do is get a four or five pin 12volt relay remove start wire from start solenoid fit a 4mm wire straight from batt pos to terminal 30 then put another wire 4mm onto terminal 87 or 87a doesnt matter from there attach that wire to the solenoid on the starter
then the original wire that was removed from start solenoid is now attached to
terminal 85 and from terminal 86 addd a wire to ground so when you start unit the solenoid pulls in and gives the start solenoid direct battery power this eliminates any voltage loss in the wiring its a pretty simple thing to do and it may help your problem either that or you are getting crap starters and also change ignition barrel to see how you go
  • Posted 12 Jun 2025 19:54
  • By skyreach
  • joined 2 Apr'22 - 40 messages
  • Victoria, Australia
reach for the sky
Indicates mandatory field
Morooka MFD20
Terberg YT182
Yale Lift Truck Technologies
Justin Byma Justin Byma
VP global product manager and strategy , Hyster-Yale Materials Handling
Chief operating officer, TVH Americas
Chief financial officer and treasurer, Universal Logistics Holdings
Director of aftermarket, Noblelift North America
Morooka MFD20
Terberg YT182
edition #1277 - 16 April 2026
In this week’s Forkliftaction News , we look at how automation continues to be an area of rapid advancement for the materials handling sector, as we saw at LogiMAT 2026, but not everyone is convinced of its value - yet... Continue reading
