Linde H30D BR 393 Year 2008
Forklift truck doesn't have enough power when driving. It has hydraulic pump HPV 75-02. Not enough Amperage on Solenoid valve for driving. When depressing pedal Amperage increase to 1000mA then starts dropping. Newer reaches 1200 mA. The same result if forklift is off the ground.
Geer pump has 23 bar.
Any idea? What else can be except maybe LHC? Some sensor??
Thanks
  • Posted 8 Dec 2025 05:56
  • By borut_veliki
  • joined 14 Dec'13 - 64 messages
  • novo mesto, Slovenia
RPM is at max. This way works a couple of years.
  • Posted 12 Dec 2025 05:16
  • By borut_veliki
Is this a new issue ? Did it run full speed previously? Does the engine run at full rpm when accelerating? Does engine rpm reach max as hyds engaged ?
  • Posted 12 Dec 2025 00:47
  • By John_Bradley
  • joined 10 Aug'22 - 292 messages
Jb69
Potentiometer should have between 0.93-4.13 V. In my case it has 1.03 and 4.17 V. fully depressed. Actual value i dont remember. So it's not that much off. Or? Will check again.....
But problem is that Amperage is dropping instead rising.....
  • Posted 10 Dec 2025 01:27
  • By borut_veliki
If the potentiometer does not operate in its full range, the LHC controller will not supply full voltage to the solenoid valve.
  • Posted 9 Dec 2025 17:42
  • By Szajbus_szef
  • joined 5 Dec'25 - 4 messages
  • Poland
It's just a little off but i don't think this could make a problem.... I've had a lot of forklifts worse position but everything worked fine. Did you have similar problem?
  • Posted 9 Dec 2025 00:54
  • By borut_veliki
If you have a canbox, check the pedal position sensor. Focus on the "final stops" values.
  • Posted 8 Dec 2025 14:06
  • By Szajbus_szef
  • Poland
Around 8-10% of people grind their teeth at night. The process is called sleep bruxism, and most people aren't even aware they're doing it.
