Low oil pressure warning
i have a Clark c30 P232l-0632-9862CN. every now and then it would ran rough and would stink when running. like lp (stink) so we parked it and installed a new lp pressure regulator, cleaned the mixer out to. Now it struggles to start. turns over about 5 times, then starts but then dies immediately and the low oil pressure warning is on the dash. Any recommendations.?
fuel all the way to the mixer. Good spark. engine oil level good. oil has 100 hrs on it. truck only has 1400 hrs on.
  • Posted 27 May 2025 15:29
  • By Hein
  • joined 23 May'25 - 4 messages
  • North Dakota, United States
Hein Terblanche
Did you get this resolved?
On that truck, anytime the key is on and the engine is not running you will get a low oil pressure warning. That said, sounds like you still have a fuel problem
Check the oil pressure with a wet gauge.
  • Posted 30 May 2025 03:34
  • By kelsey
  • joined 24 Aug'08 - 25 messages
  • Tennessee, United States
Yale releases two new products Greenville, NC, United States
May 20-21, 2026 - Melbourne, Australia
August 19-21, 2026 - Bangkok Thailand, Thailand
Around 8-10% of people grind their teeth at night. The process is called sleep bruxism, and most people aren't even aware they're doing it.
