Komatsu FB15EX-11
Hello,
I appreciated your willingness to help out others posting in the forum so I decided I might post here and ask for your help.
I am trying to fix a Komatsu FB15EX-11 Forklift, 2003 Model.
I have been looking everywhere for a list of error codes but I can't come across a manual or a book or anything. I would also like to get my hands on a technical specifications, wiring diagrams etc. as much info as possible would be great.
My main issue is the Error "FAILURE IN CONT.(T) E17 CALL YOUR SERVICE!"
Also, is there a program available to install on a laptop to clear error codes?
Much appreciated.
P.S. I couldn't upload the photo of the error on the LCD screen.
I imagine once I fix this error I will have another so I'd like to work through them one at a time.
  • Posted 21 Nov 2012 12:13
  • By Bicka
  • joined 21 Nov'12 - 4 messages
  • Victoria, Australia
Showing items 1 - 19 of 19 results.
E07 = main contactor issue, check coil/harness/wiring, if good can be board issue.
E32 = EMG switch
  • Posted 24 Mar 2020 08:08
  • By John50
  • joined 7 Sep'19 - 153 messages
  • Netherlands
Hi All;
I was looking for a solution to the problem E07 and E32 but the responses all not usable, Is there any body solve the problem ? If any body please discus here
  • Posted 12 Mar 2020 18:06
  • By ali_g
  • joined 28 Jul'12 - 2 messages
  • West Azarbaijan, Iran, Islamic Republic Of
Hello
I am facing to trouble with my Forklift. FB15EX-11. It cannot turn on now. No lamp is indicated. I tried to find down and check everything but no abnormal was found. I think about some issue with main board. Could you guys share to me some documents such as diagram, service manual, troubleshoot...for this model?
I highly appreciate your kindly help.
My email: [email address removed].
Best regards,
  • Posted 20 Nov 2018 02:32
  • By Peter7483
  • joined 20 Nov'18 - 1 message
  • Viet Nam
Hello. I would be grateful if you send me the electric diagram and other documents of Komatsu FB15EX-11 Best regards
Posted by: sky_g
  • Posted 16 Mar 2018 02:25
  • By raznosol
  • joined 14 Mar'18 - 1 message
  • Russia, Russian Federation
Best regards
  • Posted 2 Aug 2017 18:20
  • By sky_g
  • joined 2 Aug'17 - 1 message
  • moscow, Russian Federation
E05 modul power
  • Posted 12 Dec 2015 13:10
  • By nguyen_s
  • joined 5 Mar'14 - 66 messages
  • binh tan, Viet Nam
E17 sensor pedal
  • Posted 12 Dec 2015 13:09
  • By nguyen_s
Hey Mouayyad, error code 5 means that there is a problem with the power module (upper or lower one)
kind regards
Marc b
  • Posted 11 Aug 2014 18:17
  • By marc_b
  • joined 1 Jul'05 - 345 messages
  • ANTWERP, Belgium
hello marc,
hope everything Ok.
could you tell me what the meaning of the error code 5 for komatsu forklift FB15EX-11.
Best regard.
  • Posted 11 Aug 2014 08:42
  • By mouayyad_b
  • joined 23 Feb'14 - 5 messages
  • Amman, Jordan
dear all,
could you tell me what is the meaning of error code 5.
Best regard,
  • Posted 11 Aug 2014 08:18
  • By mouayyad_b
  • Amman, Jordan
Hello gursharan,
E07; main contactor (coil)
E32; emergency switch
E62; proportional valve coil is disconnected
Kind regards
marcb
  • Posted 12 Jul 2013 18:14
  • By marc_b
  • ANTWERP, Belgium
hello everyone
can somebody help me to get service manual for FB15-Ex11 komatsu.
the error codes , i am getting, are E 07, E 32 , E 62.
your cooperation shalll be highly appericiated.
  • Posted 12 Jul 2013 01:02
  • By gursharan_s
  • joined 12 Jul'13 - 2 messages
  • Delhi, India
Hello, guys. I am from Ukraine. There is not any possible way to obtain service manual for this forklift, here in Ukraine. Can you help me with the Service Manual for Fb15-Ex11 Komatsu?
  • Posted 9 Apr 2013 16:57
  • By alexbrooy_b
  • joined 9 Apr'13 - 1 message
  • V, Ukraine
Thanks Marc,
I'll check it out when I get back to work on it again. I appreciate all your help. The interesting thing is no error codes now but it wont drive at all, everything else checks out. I'll be testing the outputs from the power side of the inverter and swapping the foot switch with a potentiometer too see if I can get anything out of it.
-Bicka
  • Posted 2 Dec 2012 17:15
  • By Bicka
There's no seat switch but there is a switch on the brake cylinder and hand brake.
  • Posted 30 Nov 2012 18:52
  • By marc_b
  • ANTWERP, Belgium
I have plugged the Accelerator pedal back into the forklift and it starts up now with no errors. I still can't drive the fork. It will engage into forward and into reverse and the lights come on. But it won't drive.
Do you know if there is any safety interlocks such as a seat switch that may be preventing it from driving?
Much Appreciated.
  • Posted 30 Nov 2012 13:22
  • By Bicka
A Big Thanks to both of you for such a speedy reply! I have put my email address in my signature, I would greatly appreciate a wiring diagram if its not too much hassle.
I have contacted Komatsu here in Melbourne and they have emailed me a scan of the troubleshooting page and like you said marc_b it mentioned E17 as "Travel accelerator output is defective", Vehicle can travel at 40% of maximum speed... I will check the wiring on the pedal and make sure to test it is working properly.
It won't drive at all at the moment but I'll trace the wires back and see if they are broken or not plugged in etc.
Regards,
  • Posted 22 Nov 2012 07:53
  • By Bicka
Hello Bicka. Please your email adress. My adress is in my profile.
Best regards
  • Posted 22 Nov 2012 03:52
  • By LACI
  • joined 24 May'09 - 195 messages
  • Serbia
Hello Bicka, well I've tried also for a long time to get the shop manual of this model. I do have an electrical diagram of it, so if your in need I can send it. Normally E17 is a problem with the output of the accelerator so control it. As far as I know you can't connect a laptop on it but once the problem is solved the errors will be gone on the display.
Put you email into your profile
kind regards
  • Posted 21 Nov 2012 16:58
  • By marc_b
  • ANTWERP, Belgium
Noblelift
