intermittent power and steering failure
Can anyone tell me why i'm getting this???
What need to be fixed?
  • Posted 5 Nov 2011 07:31
  • By SteveB123
  • joined 5 Nov'11 - 2 messages
  • Illinois, United States
Edwin,
slow down when you write, it's not making sense. You can give your opinion, but hold off on the "your all wrong"
Besides, the post is very old!
  • Posted 8 Oct 2015 13:51
  • By EasiTek
again you are all wrong your steering amp has a bad capacitor top one its fill with gey silicone wrap around it go ahead touch the capacitor and see its loose every time you hit a bump the cap its arc internal on the board which you need to take off the grey silicone and look on the back of the board and see where its soldered to the top cap and see it burnt
  • Posted 8 Oct 2015 13:00
  • By edwin_q
  • joined 8 Oct'15 - 6 messages
Eddie Rod #1
The truck may not be seeing that the tiller is moving due to a bad spot in the tiller encoder. Run tests I35 and I36 and turn the tiller slowly and the count should increase CW and decrease CCW. Are there any codes popping up?
  • Posted 15 Nov 2011 07:32
  • By joe_d
  • joined 25 May'10 - 253 messages
Ain't nothing I can't fix but a broken heart and the break of day!
I'm guessing electric steer, myriad of things can cause this.
Steer encoder under handle, steer head that runs the motor.
  • Posted 15 Nov 2011 05:54
  • Modified 15 Nov 2011 05:56 by poster
  • By grego
  • joined 15 Nov'11 - 12 messages
  • Alberta, Canada
*** the steering will lock up
I turn the machine on then off, and it goes back to normal
  • Posted 5 Nov 2011 07:40
  • By SteveB123
Briefs United States
ROYPOW
Terberg YT222
Ncn 110TH
Ncn 110TH 2015
