In the subject Ithe model should have read hyster H100c- AF- 48
I have a 1968 hyster retired air force Hyster h100c -AF- 48 lift truck'
It says the lifting capacity is 10,000 pounds at 48 inches on the forks. This machine is identacle to a h150c rated at 15.000 and my h100c-af-48 has extra weights on the sides of the engine housing is rated at only 10,000 and the side weights are heavy weights.
Why is my lift truck rated at 10,000 pounds?
Is it because they are figuring the load at 48 inches out on the forks instead of the standard 24 niches.
I found a calculator and it says at 24 inches on the forks it would lift 20.000.
I have seen the previous owner lift over 16000 with it without any trouble.
My lift truck weighs 23,300 pounds and is rated ai 10,000 and a h150c weighs 19,400 pounds and is rated for 15,000 pounds.
I think my h100c-AF-48 should lift 20,000 at 24 inches on the forks. Am I wrong?
Any input appreciated.
Thanks mike
I just bought a 1966 H100C-AF-48 with the same specs. It had been sitting a while but wasn't hard to get running. The Hystermatic transmission is low on fluid, it looks bright red like Dextron. Does anyone know if this the correct fluid?
Thanks
Jeff
I think the military does tend to overbuild. and sometimes waste resources ,but I'm glad they're there.
Here is that web site to figures load center and has a capacity calculator.
They removed the url so I took off the www and the slash AT THE END.
HOPFULLY THERE IS ENOUGH THERE THAT INTERESTED PEOPLE CAN FIND IT. sorry about the caps
warehouseiq.com/calculators/load-center-capacity-calculator
from experience the military would usually use the largest truck they can to lift the smallest load. 1 site i used to got to had a 7ton truck for shifting matresses. 2 at a time !!!!lol
Thanks DeadandBloated
I was worried that my post would be confusing, but not to someone that knew how its calculated. The extra weights on the sides are factory installed.
I found one other on the net that's identical. they were advertising at 10,000 load capacity as the ID tag states. That's likely to make it harder to sell if a guy wants a heavy lifter and doesn't see or understand the 48 inch load center.
Im sure its military specific. The military probably had a specific size load to lift as you stated about the container size. its a big hunk of iron.
I play around with old metalworking machinery ,actually Im just getting started at home but worked with machinery all my life. I need a heavy lifter. Its fully functional. needs some TLC.
I spent a couple of days researching before I found that load calculator.
I will post a link to it and it may help someone else. I will have to find it again.
Thanks mllud
You are correct about the load center. 10,000 lbs. @ 48" is a lot of weight. The lift probably has 96" forks that they were using to pick up a 96" load. It would calculate around 20,000 lbs.
