Help - fault 3164
hello everybody,
I need help.
I do not know what to do anymore, the machine has been standing still for a week.
When connecting the forklift switch sometimes does not start and does nothing, it gives the 3164 fault that in the jeti tells me "Relay brake closed instead of open".
What relay is this?
Where can I find him?
Will this be the relay inside the steering controller?
  • Posted 19 May 2018 08:07
  • By k2o3_m
  • joined 14 Apr'18 - 7 messages
  • Lisboa, Portugal
Hi
I recently had the same issue including error 0304 and my first test was with K6, I checked the coil ok, Vout after closure ok idem to Vin, the only thing I noticed is that it was extremely hot more than usual.
is this normal.
please advise
  • Posted 27 Apr 2021 23:32
  • By yandier_m
  • joined 12 Jan'19 - 11 messages
  • Havana, Cuba
YMG
Small contactor is broken, locate back of the truck right side.
  • Posted 9 Feb 2021 03:35
  • By Justus
  • joined 23 Aug'20 - 37 messages
  • Finland
Hello, probably the fault is caused due to worn out contact plates on the K6 relay.
  • Posted 8 Feb 2021 03:30
  • Modified 8 Feb 2021 03:31 by poster
  • By Erwin
  • joined 26 Dec'20 - 3 messages
  • Oost Vlaanderen, Belgium
Evw
I have the same problem. I ask someone for help please....
  • Posted 7 Feb 2021 04:55
  • By BGSTILL
  • joined 4 May'20 - 3 messages
  • Bulgaria
www.mbls.eu
how did you solve this problem, please help!
  • Posted 4 Oct 2018 05:38
  • By Krapet
  • joined 4 Oct'18 - 2 messages
  • Denmark
Solved can erase.
  • Posted 14 Jun 2018 05:55
  • By k2o3_m
  • Lisboa, Portugal
  • Posted 21 May 2018 03:07
  • Modified 14 Jun 2018 05:57 by poster
  • By k2o3_m
  • Lisboa, Portugal
