Error code 243, can error 5
Does anyone have any experience with this? I have swapped the pump and master controller with a like truck, checked all the can connections and still have not found a for sure issue with the truck. Any information would be helpful. Thank you!
  • Posted 1 Jun 2016 23:50
  • By chris_hall1287
  • joined 1 Jun'16 - 1 message
  • Tennessee, United States
Check to ensure the two (2) Pin Jumper between the B1 and B2 Terminals on the Pump Controller is securely in place and is tight.
Check connections between the pump and traction control on PB9 to TB5 wire 83, PC1 to TC1, wire 73 and PC3 to TC3, wire 4.
  • Posted 2 Jun 2016 22:52
  • By Diego_deLavega
  • joined 14 Mar'12 - 14 messages
  • Kentucky, United States
Phytoplankton create at least half of the world's oxygen production, despite amounting to only about 1% of the global plant biomass. They also respond rapidly on a global scale to climate and environmental variations, so are often used as indicators of marine health.
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
