Engine not starting
Hi,sir We had done water wash and air cleaned it after that machine started well after an hour fault indicater no 96-4 came and we checked all the sockets removing and cleaning and fixed back after that now the engine is not starting only dashboard light and one round light with spanner shows and fault no 676-3 and 96-4 is flashing,please suggest me for this problem.
Thanks & Regards
Felix Dsouza
  • Posted 9 Jan 2015 18:32
  • By felix_d
  • joined 9 Jan'15 - 22 messages
  • UAE, United Arab Emirates
Showing items 1 - 17 of 17 results.
Hi Felix,
I would suggest to contact TVH UAE office Mr. Basir. He will assist you you for all your queries.
Thank you,
  • Posted 13 Nov 2015 18:59
  • By Dharam
  • joined 13 Nov'15 - 1 message
  • India
Mazda aluminum valve cover w16exr-u
Gm black valve cover t14pr-u
  • Posted 13 Nov 2015 14:48
  • By stam
I checked the plugs and they were a realy short plug they looked almost to clean to me do you think I need a longer plug hotter
  • Posted 13 Nov 2015 08:52
  • By MERC
  • joined 11 Nov'15 - 5 messages
  • Missouri, United States
was the ignition system checked at all?
sounds like plugs.
  • Posted 13 Nov 2015 08:27
  • By stam
I have a hyster s60xm that has impco mixer and impco lp filter this lift is hard starting in the moring I have replaced the impco mixer with a new one and also replaced lp filter and replaced the vacuum hoses and it is still hard to get started but once you get it started that first time after that it will start up every time the rest of the day. The engine is a 4 cylinder mazda or gm not sure. need help. note also replaced the carb diaphragm.
  • Posted 13 Nov 2015 05:56
  • By MERC
Hello Dear
We are facing pblems with our hyster 3 ton forklift. Can you please advise urgently.
Fault code-6764 and not start engine.
Thanks!
  • Posted 12 Aug 2015 12:38
  • Modified 16 Aug 2015 03:51 by poster
  • By jeyaraj_p
  • joined 12 Aug'15 - 1 message
  • dubai, United Arab Emirates
Hi sir,not getting any reply.
  • Posted 29 Jul 2015 04:21
  • By felix_d
Hi sir now there is no code error on the dash board, with more eccelerator machine is ok but in low ideal it vibrates, mountings are also ok,and fuel pump nozzles also checked ok.Thanks for your reply.
  • Posted 28 Jul 2015 05:38
  • By felix_d
Have you cleared the fault codes
  • Posted 28 Jul 2015 05:17
  • By Davecraves
  • joined 28 Jul'15 - 4 messages
  • Staffordshire, United Kingdom
Hi, Thanks for your early reply i will check and come back to.Bye.
  • Posted 14 Jan 2015 20:41
  • By felix_d
Hi,
This code means "DTC 524230-3 - Rear Work Lights Relay (RL7) Driver Output OORH".
Check the relay and the lights. Sometimes a defective ligth can cause this fault code.
  • Posted 14 Jan 2015 19:36
  • By JavierSo
  • joined 13 Jan'15 - 16 messages
  • Portugal
Hi,Thanks for your good reply,after all the checking of connectors still the engine did not start but now the code error is 524230-3 flashes,please let me know what that means,Thanks
  • Posted 14 Jan 2015 19:22
  • By felix_d
Have you checked the glow plugs?
This fault code means "Glow Plug Relay Driver Output OORH".
If you have checked all the connector maybe the problem can eb found in the glow plugs.
  • Posted 14 Jan 2015 18:33
  • By JavierSo
  • Portugal
Hello, is there any one who can help me to find out the fault,as i checked all the connectors of vsm ,and the key switch board also but nothing when i start the key switch the error code shows 676-3 and engine does not crank at all. Thanks.
  • Posted 14 Jan 2015 00:20
  • By felix_d
Hi sir please let me know whst has to be checked676-3 is flashing the fuel sensori have changed the falt is gone but still engine is not starting.
  • Posted 12 Jan 2015 20:49
  • By felix_d
yes i checked all the connectors they were not wet but still i removed and fixed back all indicators come when we on the key but 1 indicator with yellow round with spanner pictuture does not go and engine also not starting is there any password or any callibration needed but after water wash forklift was working for 1 day please let me know what else to be done.Thanks
  • Posted 10 Jan 2015 04:39
  • By felix_d
676-3 is a glow plug relay reading high. This would be on a diesel unit. 96-4 is a LPG fuel level sensor reading low. This is for a LPR unit. Sounds like you have a VSM connector that is wet. Did you remove and dry out the connectors on the VSM? It is located under the dash cove on the right hand side.
  • Posted 10 Jan 2015 00:34
  • By BREWSKI
Brussels Airport in Belgium, Europe is the world's largest sales point for chocolate, with over 800 tonnes of chocolate sold annually. This averages out to about 1.5 kilograms sold every minute.
ROYPOW
Toyota 7FGCU35
Flesherton, Ontario, Canada
Taylor TXB180S
Jim Tompkins Jim Tompkins
Sales operations, Heli
