CRANK SHAFT PULLEY COMING LOOSE
The crank pulley keeps coming loose on this V6 for some reason and has elongated the dowel holes in the pulley. I ordered a new one from the dealer and it came with no dowels -reordered and the next one also came without dowels.
Does anybody know if there was a recall or TSB on this prob?
  • Posted 1 Oct 2011 09:57
  • By troy_m
Have same issue with pulley coming loose, motor mounts are bad but didnt notice at first, have no dowel pins,is this common issue
  • Posted 7 Dec 2013 01:33
  • By dhls
  • joined 20 Jan'12 - 10 messages
I'd mic the crankshaft snout and the replacement pulley before I'd install the pulley. Usually when things keep loosening up it means the fit isn't as tight as it should be.
  • Posted 13 Jan 2013 10:32
  • By bbforks
Had same problem can't remember about dowl rods. But found that the motor mounts bushing were bad causing motor to lift up, which loosened up crank bolt causing harmonic balancer and pulley fall away and crank bolt wallered out pulley hole.
  • Posted 12 Jan 2013 03:15
  • By Dave2013
  • joined 10 Jan'13 - 20 messages
  • Oklahoma, United States
edition #1281 - 14 May 2026
Hangcha CBD15
China
USD1,600
Toyota 02-8FD30
