C500Y30 tilt cylinders will not go all the way forward
I bought a used Clark C500Y30 off of eBay from a dealer. They claimed it was totally refurbished. When I received the truck, the tilt cylinders were drifting forward quite fast. I called them and they shipped me out two repacked used cylinders. They are exactly the same length/diameter as the originals.
I got to work and pulled one of the old cylinders off. The pistons on the repacked set were not extended out as far as the originals. Changing the first, I used a ratchet strap to adjust the distance. Pulling the mast in towards the truck, I was able to get the piston bracket on the repacked cylinder positioned and attached to the mast. Then I tightened all my hose connections. I proceeded to do the same to the other side.
When I fired up the truck, the forks would not tilt all the way forward. Eyeballing it, there is easily 6 inches of unexposed piston in the cylinder. I tried cracking the hoses and bleeding air out of the lines, but only fluid came out. I also topped off the hydraulic fluid.
It seems like there should be an easy solution. This is the first set of hydraulics I have tinkered with and I probably missed some step. Any advise would be appreciated.
Thanks
  • Posted 29 Aug 2016 13:47
  • By joshua_g
  • joined 29 Aug'16 - 1 message
  • Colorado, United States
Stam is probably correct. You will have to take the cylinders apart and see if there are stops on the rams. If these cylinders came off of a truck with a three stage or very tall standard mast there will be tilt restriction spacers on the rams.
  • Posted 29 Aug 2016 23:24
  • By BREWSKI
  • joined 10 Jan'12 - 1,698 messages
Someone may have sleeved your new rams to limit fwd. tilt.
This is usually done after a salesman has sold an undersized truck or an attachment was fitted.
To know for sure a dismantle is required.
  • Posted 29 Aug 2016 21:40
  • By stam
Crown names top North American dealers New Bremen, OH, United States
edition #1285 - 11 June 2026
Libiao Robotics
