522173-4 error code No Trans Braking
forklift is cranking (starting)
but no acceleration
and is given new error Code
522173-4 No Trans Braking
best Regards
  • Posted 5 Nov 2014 18:17
  • By dib_k
  • joined 5 Nov'14 - 12 messages
  • lagos, Nigeria
Dib khanji
Dear James ,
you are right i type the wrong and the sensor socket was not connect well I've clean it and connect the lift worked but after 4 days give me another problem.
The machine will start normally in the morning
can work the whole day
If you switch it off and tried to start it immediately
it wont start till after some time (cool off) + - 2 hours
If you tried more cranking a Fault - 1684 will appear
by returning the Key to OFF position then ON again the Fault will disappear.
Best Regards.
  • Posted 24 Nov 2014 21:34
  • By dib_k
  • lagos, Nigeria
Dib khanji
are you sure the code isnt 522713-4,that is the accelerator position sensor that would be reason why you are getting no acceleration
  • Posted 5 Nov 2014 21:59
  • By JAMES2014
  • joined 5 Nov'14 - 7 messages
  • Vermont, United States
  • Posted 5 Nov 2014 21:58
  • By JAMES2014
Sue Tomic Sue Tomic
