1960 clark forktruck f4 flattop distributor options
I have a cfy50b clark forktruck that I am about ready to drive off a tall cliff. It is in need of a tuneup in the worst way and was having issues with the regulator so I figured time for ignition system tune up all at the same time. The dist that was on the machine is a delco remy model#1110412 serial#7J26 and is no longer made and has no replacement that I can find through research. While trying to remove the cast distributor adaptor on the original distributor shaft, the mounting bolt hole broke off and is not unusable. This cast piece has "C400m230" pressed into the side of it FYI.
I contacted clark and had them send me the original factory build sheet for this machine based off the serial number of the truck and the spec sheet they sent me had a different distributor listed. Now, I dont know if the build sheet is inaccurate for my application or what, but the distributor listed does not work on my machine. I ordered a pertronix 610096 as the sheet listed but it simply is not going to work on this machine. The rotating part of the dist shaft fits snuggly into the cylinder head of my f4 engine. Even if I fabbed up a way to mount the thing so that the dist shaft would not fit snug and therefor could turn freely , It would sit way to tall to be able to put the seat back on the machine.
Does anyone have any ideas on what I could do for a different distributor?
[URL=http://s1376.photobucket.com/user/Jaime_Mierow/media/build%20sheet%20picture_zpsomkiqhfc.jpg.html][IMG]http://i1376.photobucket.com/albums/ah10/Jaime_Mierow/build%20sheet%20picture_zpsomkiqhfc.jpg[/IMG][/URL]
[URL=http://s1376.photobucket.com/user/Jaime_Mierow/media/dist%203_zpsnwpruc0g.jpg.html][IMG]http://i1376.photobucket.com/albums/ah10/Jaime_Mierow/dist%203_zpsnwpruc0g.jpg[/IMG][/URL]
[URL=http://s1376.photobucket.com/user/Jaime_Mierow/media/dist%201_zpstddgh3gw.jpg.html][IMG]http://i1376.photobucket.com/albums/ah10/Jaime_Mierow/dist%201_zpstddgh3gw.jpg[/IMG][/URL]
[URL=http://s1376.photobucket.com/user/Jaime_Mierow/media/dist%202_zpsezf9q4fa.jpg.html][IMG]http://i1376.photobucket.com/albums/ah10/Jaime_Mierow/dist%202_zpsezf9q4fa.jpg[/IMG][/URL]
[URL=http://s1376.photobucket.com/user/Jaime_Mierow/media/engine%20view_zpslddfx2mk.jpg.html][IMG]http://i1376.photobucket.com/albums/ah10/Jaime_Mierow/engine%20view_zpslddfx2mk.jpg[/IMG][/URL]
[URL=http://s1376.photobucket.com/user/Jaime_Mierow/media/fork%20truck_zpslbcnluql.jpg.html][IMG]http://i1376.photobucket.com/albums/ah10/Jaime_Mierow/fork%20truck_zpslbcnluql.jpg[/IMG][/URL]
  • Posted 21 Sep 2016 00:42
  • Modified 21 Sep 2016 01:15 by poster
  • By jaime_m
  • joined 28 Aug'16 - 13 messages
  • Wisconsin, United States
I know this was a few years back, but would you still have access to 1110412 distributors, caps, rotor buttons? Thanks
  • Posted 13 Jun 2021 09:08
  • By MacraeSalvage
  • joined 13 Jun'21 - 1 message
  • Virginia, United States
I found a company by the name of Genesee Products out of Oklahoma. He makes a pedestal mount electronic distributor for 275$. Cant beat that...
  • Posted 23 Sep 2016 22:47
  • By jaime_m
What you have is the early version of the F series Continental head. I have not found a way to use the Pertronix distributor with it. To use that distributor you would need to swap to a late version head plus a distributor drive shaft and hold down device for the distributor. It is not a difficult thing, however will require some more parts. If the price of a new old stock distributor is good that would be a fine way to resolve your problem. You can also install a kit in the old style distributor to do away with the points if you prefer that.
  • Posted 23 Sep 2016 00:04
  • By Rickg
  • joined 22 Sep'16 - 1 message
  • Missouri, United States
Any good machinist should be able to make you a new adapter mount or repair yours. There isn't much stress on that adapter , I would try Devcon aluminum repair epoxy. Build it up around the broken piece after soaking entire adapter in cleaning solvent and drying. Then redrill mounting hole.
  • Posted 22 Sep 2016 21:18
  • By MtnMan
  • joined 9 Jun'07 - 8 messages
  • Alabama, United States
Yes I would appreciate a quote. Thank you
  • Posted 22 Sep 2016 01:09
  • By jaime_m
Hello Jaime
I have access to a few 1110412 original delco remy new distributors.
Let me know if you want a quote.
Matt
  • Posted 21 Sep 2016 22:36
  • By partsman1
  • joined 29 Dec'15 - 27 messages
I guess pictures do not show up on here.... If you need pics I can email a link... It wont even let me link them.
  • Posted 21 Sep 2016 00:45
  • Modified 21 Sep 2016 00:48 by poster
  • By jaime_m
SMV (Konecranes) 33-1200C
Morooka MFD20
Briefs United States
