Toll SPD - The ideal model of logistics success
- 27 Apr 2006 ( #257 )
6 min read
When an Australian transport company moving over 100 containers a week increased their labour productivity by 15%, reduced trailer fleets by 26% and increased turn around times of delivery fleets by 6 hours a day the industry stood up and took notice of what was happening at Toll SPD Brisbane.
As the ideal model of a successful restructure of operations and cost efficiencies TOLL SPD was recognised nationally by the LAA for its achievements.
So how did they do it?
The original operational procedures were reactive at best with Toll SPD applying a band aid approach to a logistical and costly nightmare.
According to Mr Lee Metselaar, Operations Manager at Toll SPD Brisbane, they did not have the ability to handle heavy equipment and large forklifts in their Brisbane yard, which is a common problem for many companies.
Mr Metselaar added that this problem limited the abilities for loading and unloading 105 containers a week and high costs associated with labour, equipment, trailers and delivery ensued.
The Old Operation
o
Due to yard restrictions incoming containers were being left unpacked on trailers. The driver of the incoming combination of prime-mover, trailer and container would park the trailer with the container on it, until the container needed unpacking (See Figure 1, Step 1)
o A yard prime-mover would then move the trailer with the container to a loading dock. (See Figure 1, Step 2)
o One forklift would then take the goods out of the container and place them at the edge of the loading dock. (See Figure 1, Step 3)
o Another forklift would then take the goods from the loading dock and place them where they needed in the warehouse. (See Figure 1, Step 4)
When the container was unpacked the yard prime-mover would then pick up the trailer with the empty container and park in the yard, ready for pick-up by the outgoing prime-mover.
The problems with the old operation
o There were too many freight movements involved when unpacking a container.
o The turn around time (dwell time) of the prime-mover/trailer combination was too long.
o The driver had to climb on the back of the prime-mover twice to couple and uncouple the air and electrical connections. This was a potential safety hazard.
o The driver had to wind the landing legs of the trailer down when parking, and up after coupling, creating a potential for back, arm and shoulder injuries.
o Parking a trailer against a loading dock is potentially dangerous, with the chance of damaging the rear of the trailer
o A forklift working on a loading dock has a higher risk for accidents than when working from the ground
o Freight was double-handled, taking valuable time and resources (forklifts).
o The distance from the container to the storage area of the goods was too far, because of the position of the dock in relation to the destination of the goods inside the warehouse.
The solution
Toll SPD acquired a Mobicon as it was the only container handler available on the market that had both the flexibility to handle all sized containers, including the 48' curtain-siders, and is designed with ideal wheel loadings suitable for the Brisbane yard.
The Mobicon is designed to handle any length container, from 20 foot (6.1 metres) through to 48 foot (14.6 metres). The Mobicon weighs only 12 tonne empty, and as the weight is evenly spread across 8 wheels, the wheel loadings are less than 6 tonne when carrying a 30 tonne container. This makes the Mobicon a lighter and safer solution than heavy container-handlers, such as forklifts or reach stackers.
The Mobicon can back containers in to tight spots and will pass through a 3.8 metre high by 4.7 metre wide door opening. This allows the operator to transport the containers inside sheds and unload into the doorways. It has the ability to move in restrictive areas and can fully utilise all areas of the yard.
The new operation
After the Mobicon was commissioned the costs savings to the container handling operations was immediate. The Mobicon has enabled Toll SPD to improve safety, productivity and to dramatically reduce operating costs.
o The number of steps in unloading the freight was reduced from 4 to 2 steps.
o The incoming combination of prime-mover and trailer with container now drives close to the warehouse. (See Figure 2)
o The Mobicon takes the container off the trailer and places it close to where the freight is needed inside the warehouse. (See Figure 2, Step 1)
o An empty container is then placed on the trailer and the driver leaves. This greatly reduces the container movements in the yard. The container is unpacked with only one forklift, which greatly reduces the time needed to empty a container because it is located close to the storage area. (See Figure 2, Step 2)
Benefits of the Mobicon
Increased Productivity by 15 to 20%:
An important improvement was the reduction in the number of operators and forklifts needed to unpack containers. Only one forklift is now used for this task, compared to two previously. Toll SPD now handles more freight in less time.
Reduction of Trailer Fleet by 26%:
Toll SPD reduced the trailer fleet from 95 to 70 which saves them approximately $100,000 annually and $19,000 less in trailer registration fees.
Reduction of Dwell Times by 6 hours:
The prime-mover/trailer combination turns around 5 minutes faster than with the previous system. Toll SPD now averages 60 turn arounds' per day, which is an improvement of 6 hours a day. The idle time of a driver plus prime-mover and trailer is $65 per hour. The Mobicon saves Toll SPD approximately $100,000 annually.
Reduction of prime-mover usage:
The yard prime-mover is now used much less which has greatly reduced its operating costs.
Increased Safety:
By eliminating the use of the loading dock to transfer freight, the need to have fork lifts working above ground on a dock is eliminated. Safety for drivers and operators is improved.
Reduced risk of injuries:
The need to couple and uncouple trailers from prime-movers is eliminated with the Mobicon. Operators do not need to climb on the back of prime-movers 6 times per container turn around. Also, the need to wind the landing legs of the trailer up and down 6 times is eliminated.
Less freight damage:
As freight movements and handling are reduced there is less freight damage. Less freight damage and faster loading and unloading of the freight has also improved customer service levels.
Reliability:
The Mobicon has proven to be extremely reliable and durable. The combination of simple technology and proven, quality components has resulted in an extremely low unplanned downtime of .5%. The Mobicon system was designed by Mr Tom Schults, and is 100% Australian designed, owned and operated.
For further information on the Mobicon System please visit: www.mobiconsystems.com
For further information please contact:
Mr Roger Vale
National Sales Manager
Mobicon
Mobile Ph.:
+61 (0) 401 490 490
rogerv@mobiconsystems.com.au
Get in touch with Mobicon Systems
Mobicon Systems
+61 (0)... Show
PO Box 7063
Brendale QLD Australia 4500
Mobicon Systems
Brussels Airport in Belgium, Europe is the world's largest sales point for chocolate, with over 800 tonnes of chocolate sold annually. This averages out to about 1.5 kilograms sold every minute.
