Won't go into Forward or Reverse
I just bought this forklift and everything was working fine for about two hrs. Then, we tried to back it up and it would not move. We were able to go forward and parked it. Now it won't go forward or reverse. The hydraulics for the forks work fine. I also noticed it will not start if the parking brake is on? Any ideas as to what the problem might be?
Thanks,
Beer_man
  • Posted 9 Oct 2014 07:55
  • By Beer_man
  • joined 9 Oct'14 - 2 messages
  • Missouri, United States
Is any option to bypass that switch
  • Posted 2 Dec 2023 05:34
  • By Sineeshgopinath
  • joined 2 Dec'23 - 2 messages
  • India
Sineesh gopinath
If you haven't figured it out yet you might want to look down and buy all the hydraulic connections on top right of the transmission there's two connectors for the switches they get dirty and cause bad connection.
  • Posted 22 Feb 2019 10:56
  • By thomas_t
  • joined 9 Jan'19 - 3 messages
I found the switch and it seems to work for the dash light. How do you test the shift side?
  • Posted 9 Oct 2014 10:57
  • By Beer_man
Check your parking brake switches,there are two,one is for the dash bulb the other is for the start circuit and also provides the ground circuit for the fwd/rev Solenoids.either there is a wire off of the switch or the switch itself is bad,switches are located at the top of the park brake foot pedal....
  • Posted 9 Oct 2014 09:39
  • By kevin_t
Crown RD572513TT6860R
UN Forklift FD25T-C2JM1
