Wont fully extend or tilt under load
Hello everyone,
I am experiencing a problem with the SC4000 at my work.
Under any load, once the second section of the mast extends, the forks will no longer tilt. Also, once it reaches a certain height, It will just stop extending all together, even though it has a couple more feet to go.
There are no codes, and nothing seems to be wrong with the mechanically wrong with the lift system.
Has anyone else experienced this? Anything to check, that maybe I overlooked?
  • Posted 28 Feb 2018 08:09
  • By Bedrock_J
  • joined 28 Feb'18 - 1 message
  • Oregon, United States
This unit has a tilt interlock system. Once the mast opens, you will only be able to tilt fwds about 2 degrees instead of the usual 6. Or, if you have already tilted fwds more than 2 degrees and then you lift the forks and the mast opens, lift will cut out until you tilt back to under 2 degrees. It is a design feature.
If the forks are raising ok with the mast open and then stop then the switch on the L/H tilt cylinder requires adjustment/replacement.
  • Posted 2 Mar 2018 15:47
  • By techno_nz
  • Canterbury, New Zealand
Around 8-10% of people grind their teeth at night. The process is called sleep bruxism, and most people aren't even aware they're doing it.
Combilift Ltd
Justin Byma Justin Byma
VP global product manager and strategy , Hyster-Yale Materials Handling
Chief operating officer, TVH Americas
Chief financial officer and treasurer, Universal Logistics Holdings
Director of aftermarket, Noblelift North America
May 20-21, 2026 - Melbourne, Australia
August 19-21, 2026 - Bangkok Thailand, Thailand
edition #1277 - 16 April 2026
In this week’s Forkliftaction News , we look at how automation continues to be an area of rapid advancement for the materials handling sector, as we saw at LogiMAT 2026, but not everyone is convinced of its value - yet... Continue reading
