will move forward and reverse but will not lift or lower. Was working just fine
I have a 8HBW23 was working just fine but now will not lift or lower. It does move forward and reverse what should I be looking at fluid is good
  • Posted 23 Sep 2023 05:58
  • By James_Morton
  • joined 23 Sep'23 - 1 message
James Morton
sorry Trenton I've tried replying to the original post but I guess it not an option in this forum set up,
either way I'm hoping if either of you guys sees this you'll be able to explain to me what you guys have done
I have the exact same problem in the original description and looked everywhere for the limit switch. My sup wants me to start with the limit switch though I read that the solenoid can be bypassed with a 24v contactor to eliminate the solenoid as the issue. It sounds like you guys have a manual, not too sure how guarded that is but if you could tell me if there's a limit switch on this model or its location I would really appreciate it. I did read in the operator hand book about setting the height with the bolt behind the left fork I might me4ss with it a bit and see if I don't screw it up some more, Thanks for your guys help -Nic C
  • Posted 11 Jun 2024 05:22
  • By nicolas_cuev
  • joined 11 Jun'24 - 1 message
Have you check the Solenoid on the side of the Pump? sometimes it gets stuck.
Or your cable going to your tiller handle has a short.
Or your High Limit Switch is stuck on.
  • Posted 28 Nov 2023 00:38
  • By Trenton_Wilson
  • joined 28 Nov'23 - 1 message
  • Missouri, United States
Trenton Wilson
