Voltage at gray maget/box
unit has 3228 hours. Drive unit slow or lift forks slow, Engine rpm is fine. As you accelerate voltage climbs. When voltage at gray magnet hits 9 volts,linkage sticks and rpm is wide open. Tried another magnet and same results. Same thing happens if your lifting forks. Slow is fine, then when you pull back lift lever to raise faster linkage sticks and rpms are wide open
  • Posted 2 Mar 2017 14:05
  • By edward_m
  • joined 11 May'15 - 111 messages
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
Terberg RT403
Toyota 8FD30
Singapore
USD18,000
Neptune was discovered in 1846. It then took 165 years, or until 2011, for the planet to complete one orbit of the sun.
