Unit will move forward & reverse; will not lift
Unit beeps once upon switching on; battery indicator lights show 4 lit LEDs - steady at first, then regular blinking. Unit will move forward and backwards, however; when UP button is pressed, unit beeps and will not raise; this repeats each time UP button is pressed. Hydraulic fluid level OK. No codes showing. Internal fuse checks OK.
  • Posted 17 Dec 2014 02:36
  • By rudi_s
  • joined 17 Dec'14 - 5 messages
Did you ever fix yours?
  • Posted 2 Jun 2024 22:31
  • By Surinamerica
  • joined 28 Jul'19 - 8 messages
Lift it!
Rudi,
Were you able to figure out what was wrong with the pallet jack, no lift? I'm having the same problem with mine.
Thanks.
  • Posted 16 Oct 2020 13:07
  • By Juan_Alba
  • joined 16 Oct'20 - 4 messages
Juan A.
What you are describing is lift interrupt. The Zapi controller is seeing lower voltage than what you are seeing. Try charging the batteries.
  • Posted 20 Dec 2014 09:31
  • By BREWSKI
  • joined 10 Jan'12 - 1,698 messages
this unit should have an 'upper lift limit cut out switch", that stops lifting when it is activated and can get stuck or bent.
  • Posted 17 Dec 2014 09:59
  • Modified 17 Dec 2014 10:29 by poster
Have an email to post IN YOUR PROFILE........?
  • Posted 17 Dec 2014 07:11
  • By kevin_t
No LED on ZAPI controller. Check 5amp fuse on ZAPI and large fuse on front - both good.
  • Posted 17 Dec 2014 07:09
  • By rudi_s
Look on the zappi controller at the LED there and see if/what the blinking sequence is there....
  • Posted 17 Dec 2014 06:44
  • By kevin_t
Just switched tiller head controller with another same model Yale electric jack - same symptoms showed up. Other jack was red-tagged but with different symptoms (I think).
  • Posted 17 Dec 2014 06:39
  • By rudi_s
I Suspect since you can move the truck fwd and rev that you have a problem with the up down control switches or with the control card in the tiller head........
  • Posted 17 Dec 2014 06:12
  • By kevin_t
Just a single repetitive blink, about once per second, all four LEDs at once.
  • Posted 17 Dec 2014 06:07
  • By rudi_s
When you say blinking led on dash........how many blinks.....does it blink say two times then pause then blink two again??? This is giving you a code and we need to know how many blinks....
  • Posted 17 Dec 2014 04:54
  • By kevin_t
Model #:MPB 040 EN24T2748
SN: B827N30597F
24V
I put a voltmeter across the battery - it read 25V. Meter did not go down when moving jack nor when pressing lift button.
  • Posted 17 Dec 2014 04:47
  • By rudi_s
Have a full model AND serial number of the truck???
  • Posted 17 Dec 2014 04:33
  • By kevin_t
What is the battery condition...is is charged or dead? Sounds like the truck is foing in to lift cut out mode.....put a voltmeter on the battery and check the voltage when you lift or when its driven and see what it drops to....what voltage is the truck. 24 volt???
  • Posted 17 Dec 2014 04:22
  • By kevin_t
edition #1303 - 15 October 2026
In this week’s Forkliftaction News , we report on a number of product launches including an Auto-Navigation Forklift Robot from Chinese equipment maker Leapting, developed for utility-scale solar construction sites... Continue reading
October 28, 2026 - Melbourne, Victoria, Australia
November 3-6, 2026 - Shanghai, China
The term 'Genuine Leather' is not used to reassure you that the product is made of leather, but rather to indicate that the lowest quality of leather is used.
