ufs200dtfvxe525 Atlet Error 107
Hi,
Looking for some help to find out the reason why this truck ufs200dtfvxe525 is showing up with an error 107
Can someone let me know where I can start?
Thank you.
  • Posted 13 May 2022 10:17
  • By luis_v
  • joined 25 Feb'07 - 127 messages
  • Mexico
lvelasco@insercomm.com
Hello!
Great information as well as outstanding time response, I will put into practice what you have told me about this error 107
I expect it can be cleared, after all, however, it is not, I will be back to you to ask you for further information according to what I got
GUANAJUATO Muchas Gracias!
  • Posted 14 May 2022 01:10
  • By luis_v
  • Mexico
Hi Mr Velasco: the error code is steering control, you can start with checking the wire harness,on steering wheel on the armrest if looks good you go into the atlet service manual you can see waht the component that is cousing the problem, you need a password to go into atlet service manu, heres the password 0002468 then go into run test press enter go to read error codes using the arrow up till you see read error codes press the "i on the bottom left sode corner of the key pad that will give you extra explenation, si necesitas mas ayuda por dejame saber gracias seurte!
  • Posted 13 May 2022 23:44
  • By GUANAJUATO
  • joined 3 Jan'15 - 67 messages
  • Illinois, United States
Noblelift
Noblelift
