trouble code
Have electric 24v toyota pallet jack. Driver using during rain,stopped working. Dried out still will not operate. Getting codes E 115 and E116. Checked batteries test OK. Any thoughts or help greatly appriciated. THANKS
  • Posted 15 Oct 2014 06:35
  • By pheasanthunter
  • joined 15 Oct'14 - 2 messages
  • New Jersey, United States
Code E115 - Contactor Off, Welded or Missing, or Faulty Power Amp
Reason: Controller could not close contactor (contactor OFF),contactor welded, or contactor missing.
Possible Cause with Corrective Actions/Checks:
Contactor did not close (contactor OFF).
1. Problem with main contactor tips.
a. If contactor clicks prior to getting this code, try polishing the
contactor tips with a clean pencil eraser. If this does not work or
there is permanent contactor damage, replace the contactor.
2. Low voltage.
a. Try closing the contactor with a good battery.
3. Short in the contactor coil.
a. Replace the contactor
Contactor welded.
1. Main contactor tips welded.
2. Short circuit in contactor circuit.
a. Check the contactor wiring (coil) and cabling.
Contactor missing.
1. Open circuit in the contactor circuit.
2. Faulty power amplifier.
a. Check the power amplifier for error code.
b. Check the power wiring.
  • Posted 17 Oct 2014 23:17
  • By LTS1
  • joined 18 Dec'13 - 74 messages
Did you check battery short to frame? I think up to 3 volts is acceptable. Anything beyond that, the battery need to come out and everything cleaned. Does the contactor close when you power up the machine?
  • Posted 17 Oct 2014 23:13
  • Modified 17 Oct 2014 23:20 by poster
  • By LTS1
I have check the voltage thur out the machine. All is 24v right up into the harness running up the handle. But non of the controls when activated in the handle produce any voltage back down the harness out of the handle to the solenoid or horn.
  • Posted 17 Oct 2014 22:59
  • By pheasanthunter
E115 is a Main Contactor Fault. Contactor tips could be welded together, or contactor could be bad. Check wiring and voltage at contactor. If wiring and voltage are ok. Replace contactor. Hope this gets you going.
  • Posted 17 Oct 2014 13:28
  • By LTS1
Maxlion ESD15M
Taylor TX330S
USD159,500
