transmission issues, serial A78700716
Trans stuck in reverse, replaced forward reverse switch, no change. Paid Cat. tech $400.00. Transported to another shop. Transmission started working normally. Used on several jobs. Moved to job backed into parking location ( may have turned ignition off while still in reverse. Cranked lift couple of days later stuck in revers. While pulling lift forward with engine running if I shifted into forward or reverse trans would pull in reverse. Mechanic has pulled shift solenoids, checked fluid pressures all appears proper but lift stays in reverse. Any genius' that can Help.
Thanks
  • Posted 24 Oct 2019 02:02
  • By sam_ellis
  • joined 24 Oct'19 - 1 message
Sam
Michel Denis Michel Denis
Aichi RX07B
Ncn 85TH
Ncn 85TH 2014
Aichi RX07B
Ncn 85TH
Ncn 85TH 2014
