Trans fluid
Does anyone know if Hyster requires a special fluid for their transmissions, and if so what is the aftermarket style. Truck in question is a S50XM. The fluid in there now is clear ( well once was ).
  • Posted 4 Oct 2008 00:33
  • By roadtek
  • joined 4 Dec'07 - 123 messages
api gl-4 mf m 1145 ze te-ml 03e/osf/o6k 17e volvo ce wb 101 ford m2c 134d john deer j20c good for hyster transmisie and hyd. not foor zf transmisie new 8+ton
  • Posted 1 Dec 2012 18:38
  • Modified 1 Dec 2012 18:38 by poster
  • By AAPEE
  • joined 28 Aug'12 - 76 messages
  • Brussels, Belgium
I could not find Hydraulic 56 oil, but could find J20C from Tractor Supply. Will this work for a Hyster S50XM? Thanks guys,
Curtis
  • Posted 29 Nov 2012 22:31
  • By TOPTRUK
  • joined 29 Nov'12 - 3 messages
  • Michigan, United States
use hyd 56 oil in trans atf will break down plates
  • Posted 23 Oct 2010 00:06
  • By bryan
  • joined 19 Oct'10 - 9 messages
Thanks Kevin. I appreciate the reply.
  • Posted 7 Oct 2008 03:54
  • By roadtek
s 50xm will need j20a or j20c grade oil for its transmission but smaller trucks h2.00xms for example use atf oil.
  • Posted 7 Oct 2008 03:45
  • By kevin_k
Hyster
