Code T248
Hello, I have an '07 with VW LPG engine. Code T248. Code sets when traveling at full throttle, and during full lift request when engine reaches full rpm. I have replaced the speed sensor in the bell housing. It looked like it had been scrapping on the flywheel. The flywheel shows some wear on the teeth. I also replaced the potentiometer on the accelerator.
Also if I need to replace the flywheel, can someone give me direction.
Do I pull the motor, or the pump assy. I have a Linde repair manual it says nothing about flywheel replacement
Thank you in advance for any input.
  • Posted 9 Feb 2017 06:32
  • Modified 9 Feb 2017 06:33 by poster
  • By Libbey
  • joined 8 Jun'11 - 23 messages
Hey Fred,
Sorry for the late reply. I don't work on Linde a lot.
The code sets because of erratic reading from the speed sensor.
You could have metal stuck on the sensor or the sensor is to far away from the flywheel ring. I think I paid around $70. I would replace the speed sensor and be done with it.
Hope that helps
  • Posted 28 Feb 2019 05:59
  • By Libbey
Hello, I FOUND YOUR ADDRESS email on a discussion board. Can you help me with my problem? I recently bought a forklift linde. It tells me the error code T248. We have changed, the ring gear, the starter and all the other parts in this sector.
Thanks
  • Posted 26 Feb 2019 02:13
  • By fred_g
  • joined 26 Feb'19 - 1 message
  • Quebec, Canada
Fred
I finally got to the repairs. Changed the flywheel ring, rubber pump coupler, and installed a starter from Linde. Works fine. The operator says the engine performance when driving and lifting is better. The problem all started when we started purchasing aftermarket starters. Linde starter is twice the cost, but it could have eliminated changing the flywheel.
Thanks for the input.
  • Posted 27 Mar 2017 23:16
  • By Libbey
Good Morning RobJob,
Thanks for the reply. That's what I was afraid of. Have the parts ordered. I'll add the disc. I'll update after the repair. Thanks again.
  • Posted 13 Feb 2017 23:21
  • By Libbey
Chances are yes, you will need to change the ring gear. It's easier to remove the pump assembly. once the flywheel is off knock off the gear heat helps. Heat up the new ring gear evenly, pick it up with some pliers and drop it on the flywheel. Make sure it is seated and then start reinstalling everything when cool. While you're in there you may as well change the fabric coupling disk.
  • Posted 12 Feb 2017 12:44
  • By RobJob
  • joined 8 Oct'13 - 11 messages
  • Quebec, Canada
Ice 28INCH-AUTO-SCRUBBER
USD8,350
Taylor X550M
Yale Lift Truck Technologies
USD8,350
Taylor X550M
