Drive
Hello, I have a H18CT-02 and I have the issue of losing my drive.
It will be operating fine then I lose the drive forward and reverse and a light comes on the control panel. To get it going again I turn the key off and restart and it works fine until the next time.
Can anyone help with this problem.
  • Posted 18 Dec 2016 04:18
  • Modified 18 Dec 2016 04:19 by poster
  • By TLBob
  • joined 18 Dec'16 - 2 messages
I believe the issue is in the accelerator assembly. There are 3 (I think) plastic gears and if they have the slightest wear will cause this issue. Replace the gears and accelerator potentiometer and it should cure the problem
  • Posted 8 Jan 2017 23:37
  • By duodeluxe
  • United States
duodeluxe
Hi Bob, your mchine was very old for me , commonly for 350 the diagnostic 4 poles connector is located below the hydraulic control levers, then you need a truck doctor diagnostic or linde test module to connect and read the error codes.
  • Posted 24 Dec 2016 19:49
  • By melvin_p
  • joined 25 Nov'16 - 15 messages
  • QUEZON PROVINCE, Philippines
Where would I find the error codes? The light is on the panel with the head lights the same light as when you first turn the key on before starting.
Serial number is 350J04310518.
  • Posted 24 Dec 2016 05:51
  • By TLBob
HI, what is the error code when a light comes on the dsplay?
what is the serial number of machine?
  • Posted 24 Dec 2016 04:00
  • By melvin_p
Brussels Airport in Belgium, Europe is the world's largest sales point for chocolate, with over 800 tonnes of chocolate sold annually. This averages out to about 1.5 kilograms sold every minute.
Jim Tompkins Jim Tompkins
Sales operations, Heli
