Call for help
Hi Guys
I have got a forklift that assemble in china, use ZAPI controller DualAC2 Power. And now it got some wrong that it can not move or lift. The indicator show Alarm 103 and ON NODE 16. How was it wrong and what should i do?
Thanks a lot.
  • Posted 24 Jul 2016 00:40
  • By trinh_jason
  • joined 24 Jul'16 - 2 messages
  • Ha Noi, Viet Nam
Look for the best.
maybe this is a malfunction, ECO SMART DISPLAY, or there is no communication between ECO SMART DISPLAY and other units.
node 16 is ECO SMART DISPLAY.
  • Posted 30 May 2024 18:38
  • By alexandr_k
  • joined 6 Dec'11 - 197 messages
  • Ukraine, Ukraine
ntt2004@ukr.net
Alarm 103 on the ZAPI controller typically indicates a communication issue between the controller and the machine's components. Check the wiring connections, inspect for any physical damage, and consider resetting the controller. If the problem persists, contacting a certified technician for diagnosis and repair is advisable. https://gbwaapps.com
  • Posted 30 May 2024 04:51
  • Modified 2 Jun 2024 05:55 by poster
  • By mitchel_stark
  • joined 30 May'24 - 1 message
  • Singapore
NODE 16 IS THE DISPLAY.
If you can find a manual for the zapi smart display it should have the code.
This Hyundai model uses the zapi dual system https://manualzz.com/download/947304
  • Posted 1 May 2020 04:25
  • Modified 1 May 2020 04:30 by poster
  • By JonoG
  • joined 15 Feb'19 - 77 messages
  • Uruguay
Jonathan Gill
Firstly, when we talk about truck controlled by zapi controller, if you don't have manual of this truck you must have a "programming consol zapi" to connect it directly with the controller to know the fault from the controller
  • Posted 10 Sep 2018 02:55
  • By rachid_e
  • joined 27 Aug'18 - 9 messages
  • Morocco
Mr R
how many controllers does this unit have and make and model would help
  • Posted 19 Jan 2017 21:51
  • By redbull
  • joined 14 Oct'16 - 108 messages
  • Queensland, Australia
Hello
Did you find the fault.
I have the same code. All functions ok.
  • Posted 11 Nov 2016 08:05
  • By colin_m
  • joined 11 Nov'16 - 1 message
Thanks swoop223 for your caring
The machine is a forklift that use ZAPI controller DualAC2 Power. It move slow and lift slow, and the screen show upper line alarm 103 and under line node 16.
Yes, i've looked Zapi manual that i found on internet and did not find the alarm. that why i look forward to our forum
thanks
  • Posted 2 Aug 2016 21:16
  • By trinh_jason
  • Ha Noi, Viet Nam
well if you do not provide a model and serial number of machine or model number of zapi controller it will be hard to help.
all zapi manuals i've looked at do not have Alarm 103 and we cannot know what node 16 is , that is assigned by truck mfg when they design truck.
having a service manual for this truck will be necessary to identify node 16 and have the correct model of zapi controller to get correct meaning of Alarm 103.
  • Posted 25 Jul 2016 01:29
RAEDER-VOGEL
