Error code
Hyster model W40Z, serial number B218N05812B. EP 108. Had a code AL10. Followed the limited troubleshooting I had for that code and replaced Zapi controller. Ran great for about 20 minutes then started throwing code AL14. Will do it when trying to traveling in high speed in either direction. Lift stops and will not move or go up or down. If your reset the handle, it goes to working again until high speed is called for. Any ideas? All battery cables are new and it had a full charge on it. One battery is new, the other three are a couple of years old. I also replaced the wires from the battery connector to the battery charger and the battery charger is about two weeks old.
  • Posted 12 May 2015 07:59
  • By lvscr
  • joined 24 Apr'14 - 41 messages
  • Idaho, United States
I have a W30ZR with the industrial 24 battery and have codes AL06 and AL10 any help would be greatly appreciated.
  • Posted 11 Jun 2025 03:49
  • By Gotcha2000
  • joined 15 Dec'17 - 42 messages
  • Indiana, United States
Gotcha2000
Just posted it.
  • Posted 13 May 2015 13:33
  • By lvscr
Have an email address to post in your profile????
  • Posted 13 May 2015 07:22
  • By kevin_t
I have 55 ohms on one and 50 on the other(I have two controllers). Not having a wire schematics kills.
  • Posted 13 May 2015 05:30
  • By lvscr
alarm 10 and alarm 14 are related depending on the software version in the controller, older versions would show the alarm 14
cause is fault in the main contactor
Main contactor coil shorted/open.
Check contactor coil for correct resistance of 45 to 55 ohms.
  • Posted 12 May 2015 21:03
Taylor X550M
Komatsu FD25T17
Taylor X550M
Komatsu FD25T17
Sue Tomic Sue Tomic
