No up or down
I cleand it then not working was fine befor moves f b fine
  • Posted 24 Jul 2014 15:26
  • Modified 24 Jul 2014 15:28 by poster
  • By Mpare1
  • joined 24 Jul'14 - 4 messages
M pare1
yeah there is always that pesky wire harness in the handle, always seems to break wires at the base where it pivots. Don't know why i didn't think of mentioning that but had to start somewhere.
Glad you figured it out. :o)
  • Posted 28 Jul 2014 22:44
Thank you all I would have never got it if not for the tips! It was the red supply wire up to the handle was broken at the hing with one other took my time sneaked a new wire not that hard just take your time thank you m pare
  • Posted 28 Jul 2014 01:41
  • By Mpare1
this is a pallet jack. there is a switch at the top of the lift linkage stroke to shut off the pump power when all the way up. the arm on the switch can get bent, and the switch itself can go bad. locate that switch under the cover, and check by jumpering the wires. do not leave the wires jumpered as you will damage other components. Or better yet, get a crown tech to check it out, as you can get hurt trying to work a jumper wire while the truck may lift.
  • Posted 26 Jul 2014 06:17
  • Modified 26 Jul 2014 06:19 by poster
Do you hear any clicking when you press the up button? Could be a faulty solenoid.
also check and make sure it is not in lift lockout due to low battery.
  • Posted 26 Jul 2014 05:56
How did you clean?
  • Posted 26 Jul 2014 00:22
  • By bbforks
Look for a discconet wire in the solenoids valves
  • Posted 24 Jul 2014 16:01
  • By mike_raymond
  • joined 18 Jul'14 - 9 messages
  • baja california, Mexico
Moves frount and back all selonods and pump looks very new.just no up and down?
  • Posted 24 Jul 2014 15:48
  • By Mpare1
M pare1
Help please
  • Posted 24 Jul 2014 15:38
  • By Mpare1
M pare1
edition #1257 - 20 November 2025
