Taylor Forklift won't move much
Hi all! Bear with me...This is my first time on here. I have a small Taylor forklift that I started having trouble with. It doesn't want to move forward and backward. You can put it in gear and feel it shift but when you rev it up it barely moves. It was working fine last year. I just changed the hydraulic filter. It also has a hydraulic pressure gage that looks to be reading high. Finally, it is sputtering fluid from the breather on the transmission fill tube. I was wondering if perhaps some valve is stuck?? Any thoughts would be appreciated. Thanks! Matt
  • Posted 3 Apr 2014 06:58
  • By matt_k
  • joined 3 Apr'14 - 1 message
  • Wisconsin, United States
Sorry guys but we do not monitor ths board for messages. On an Allison trans the most common problem when oil is coming out of the fill tube or breather, the level is too low and the oil starts to foam. This pushes it out.
Idling in neutral - pressure should read abut 175 psi.
  • Posted 15 Jul 2016 01:36
  • By TaylorTech
  • joined 14 Nov'08 - 2 messages
  • Mississippi, United States
Hey Matt i know 2 years has went by. i have a taylor same as yours y12 ws and it wont move now happened last summer Just wondering if you know what happed to yours Thanks Kevin
  • Posted 1 Feb 2016 11:38
  • By justolkev
  • joined 1 Feb'16 - 1 message
  • Manitoba, Canada
Briefs United States
Yale Lift Truck Technologies
