pe-4000-60
the lift won't reverse until the forward is hit? any thoughts?
  • Posted 19 Mar 2014 13:49
  • By theodore_m
  • joined 19 Mar'14 - 1 message
if this truck is equipped with fwd/rev contactors make sure they are making contact.
engaging fwd might be seating the normally closed side of the fwd contactor tips.
as chevotaman said above.
  • Posted 22 Mar 2014 20:59
  • Modified 22 Mar 2014 21:00 by poster
  • By stam
so what it may be is just a switch problem where you need to actually go through nuetral and you don't do that unless you twist back from forward switch engagement.
  • Posted 22 Mar 2014 08:31
Also Keep your safety reverse switch (red belly bump button on control pod) circuit in mind. Are you getting fault code when the truck fails to travel when commanded to do so?
  • Posted 22 Mar 2014 03:13
  • By chevotaman
  • joined 28 Feb'14 - 112 messages
It's all just nuts n' bolts.
Which controller do you have? Curtis, SEVCON, etc? Do you have a handset for your controller? Just off the top of my head based on info provided you may have contactor issues??? Sticking/welded/burnt tips? If memory serves this model had directional contactors, 1-A and anti-tiedown I would start there.
  • Posted 22 Mar 2014 02:58
  • By chevotaman
Sue Tomic Sue Tomic
