J2.00XMT / G160A06719B .
The machine stops while running and displays the Following Error
266 - Traction motor Field Shorted
68 - RH Traction PMT Signal in Run Mode
if we Made key switch OFF and then Again ON it will work and After Some time Error repeats. I had Connected GE Hand tool on the machine and Found the Error -44.Its Written as REC Shorted. Where it is Located. ? Please Explain
  • Posted 28 Sep 2013 19:35
  • By lishoy_t
  • joined 29 Oct'12 - 70 messages
  • dubai, United Arab Emirates
lishoythomas619@gmail.com
sounds to me like he needs to check a couple of things before I/we blame the controller.
1st pull the battery out and clean all the corrosion from under the battery, a lot of wif [Weird Intermittent failures] are caused by signals through the frame and battery corrosion. replace ANY power cable that has been laying in the corrosion and has ANY damage or change to the insulation.
2nd, talk a good eyeball to every one of the traction motor brushes, make sure they are not stuck in the holder and are free to move and not worn out and the brush springs are good.
THEN if you still have wifs, start to consider the controller.
just my.02USD
  • Posted 4 Oct 2013 20:15
all rec's and transistors are internal to the motor controller on the SX and SR controllers
sounds to me like you have a bad controller
  • Posted 3 Oct 2013 22:57
I found different explanation for error code 44. I suppose that you have problem in traction controller.
Armature transistor did not turn off properly.
Possible Causes: Malfunctioning controller. Replace traction controller.
Cause: This status code is displayed when, during motor
controller operation, the armature transistor fails to
turn off. This will result in a PMT condition.
  • Posted 3 Oct 2013 22:43
  • By FunnyForklift
  • joined 13 Jan'12 - 18 messages
  • Finland, Finland
funnyforklift(a)gmail.com
TCM FHD105Z
Terberg YT222
St. Louis, MO, United States
Atlanta Savannah Orlando Tampa Jacksonville West Palm, United States
Ottumwa, IA, United States
RAEDER-VOGEL
Dwight Klappich Dwight Klappich
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
Executive director, NT WorkSafe
Chief executive, Logistics UK
