About error Code A0-4 on a Toyota
I have a Toyota forklift Model # 7FBCU18, just recently it come up with a Code A0-4. It will run for about 10 minutes and then it stops and can not be restarted. I search Google the code and it is telling me that the traveling system fan; shorted; limited drive output. How can I fix this problem.
  • Posted 17 Aug 2013 10:47
  • By jesse_n
  • joined 17 Aug'13 - 1 message
I would start with checking to see if you have voltage at the fan or if there is something stopping the fan from coming on. It could be just a bad fan.
  • Posted 20 Aug 2013 11:28
  • By rogeriwt
Atlanta Savannah Orlando Tampa Jacksonville West Palm, United States
Ottumwa, IA, United States
St. Louis, MO, United States
The black box flight recorder was invented by Australian scientist David Warren in the mid-1950s. While initially met with indifference in Australia, his invention gained international recognition, particularly in the UK, and is now a mandatory piece of safety equipment on all commercial aircraft.
