Does not start
Could you suggest me any idea about a RRE160 (2009) which does not appear anything in its display and does not start.
Fuses are ok. The green light is open in the main unit. The relay does not close.
Any idea?.
Thank you
  • Posted 3 Aug 2013 21:41
  • By panagiotis_a
  • joined 17 Sep'11 - 29 messages
  • ATHENS, Greece
HI, Jack Up the truck, Take one more truck or battery from other truck, fixed in this truck, check for the operation for 30 mins, If the same problem repeat, the problem is in Logic box.
As for my knowledge the problem in the battery, Also check the voltage, the total voltage should be minimum 48 Volts,
  • Posted 20 Apr 2014 01:55
  • By gopal_s
  • joined 29 Oct'12 - 156 messages
  • karnataka, India
GOP
Please have any idea? To help me?
  • Posted 15 Apr 2014 13:58
  • By jawad_b
  • joined 14 Apr'14 - 2 messages
  • Stret 1, Saudi Arabia
Hi sir,
I pay industrial truck rre160m befor 9 months we not use it more but now when start coming hang and stop working , after off 10 mintes it's work 5 mintes and hang again caming erorr 130 in display but i did not now what the prablem please let me what i do.
  • Posted 14 Apr 2014 09:03
  • Modified 14 Apr 2014 09:05 by poster
  • By jawad_b
Thanks for the reply, I will check it tomorrow.
  • Posted 4 Aug 2013 00:21
  • Modified 4 Aug 2013 02:04 by poster
  • By panagiotis_a
  • ATHENS, Greece
The CID ( Central Information Display ) hasn't got a green light on it - the display unit with the controls on is the CID.
The grey box with the single green led & 2 connector plugs is the MCU ( Main Control Unit )
The cooling fans on a RRE only work when the MCU activates them, they don't run all the time like the older model Reflex.
Have you checked the battery isn't defective?
Check / tighten the 3 nuts under the trucks battery isolator plug - DISCONNECT the battery first before you go in with the 13mm spanner!
Loose isolator nuts where a known issue, that's Toyota quality control processes for you.
  • Posted 3 Aug 2013 23:44
  • Modified 3 Aug 2013 23:44 by poster
  • By Forkingabout
  • england, United Kingdom
Hi,
I can't see any error in bisplay because is off and does not open. I disconnected from the battery but nothing.I checked the connector plugs under the plastic cover too and are ok.
The problem begun after they connect the battery from the end of charging.
A strange thing is that from the fan which cool the units , I hear a noise like tzzzzzzzzzz and dos not work.
What do you mean emergency open? How I can do this?
Thanks
  • Posted 3 Aug 2013 22:49
  • Modified 3 Aug 2013 23:46 by poster
  • By panagiotis_a
  • ATHENS, Greece
So the truck is totally dead?
CID doesn't light up / wont allow you to view truck info or errors when I button is pressed?
You got a BT can service key?
Have you tried disconnecting the battery for at least 1 minute & then reconnecting?
Have you tried starting the truck in emergency mode?
Is the CID actually still plugged in? Lift the arm rest cover, the storage pocket & then check both the connector plugs hidden under there for the CID.
  • Posted 3 Aug 2013 21:56
  • By Forkingabout
Briefs United States
